Painting chipboard?
What is the best way to seal chipboard for painting. I tried painting my one piece I made  last night and it's not only ruff but the paint does not go on nice. It's just craft paint if that makes any difference
Chipboard is cardboard. Your paint is probably soaking in, which affects the finish. You might try giving it a coat of gesso, which is what artists use to prime their canvases. It will seal the surface, so subsequent layers of paint will not penetrate. Once dry, the gesso offers a smooth surface that takes many kinds of paint very well.
You do mean chipboard and not particle board or OSB (oriented strand board), right?
That's just what cricut calls it. It's 2mm thick paper/MDF/sawdust so it will soak up paint or glue like a sponge. Definitely try using gesso or mod podge to seal it before you put on your actual paint.
