hubfd Posted July 17, 2022 Share Posted July 17, 2022 Hello, I'm renovating a beacon hill. I want to 'remove' the wooden panels on the exterior, to look flat. I'm thinking about using Darwi modelling clay to put a layer on the wooden panels. But it will take a lot of clay and it is difficult to get it plain. Do you have any suggestions? I've also tried to do it with spackle, but it didn't work at all. Quote Link to comment Share on other sites More sharing options...
fov Posted July 17, 2022 Share Posted July 17, 2022 I'm not sure what you mean by "wooden panels". The clapboard siding on the walls? Or the rectangular panels under the bay windows? (Or something else?) If you're talking about the siding, the best way to do that would be to remove it, but depending on how it's glued that could be a messy process. It would probably require taking everything else off (windows, trim, etc.) and sanding with a power sander. If you're talking about the decorative panels under the bay windows, those should be easy enough to pop off. Quote Link to comment Share on other sites More sharing options...
hubfd Posted July 17, 2022 Author Share Posted July 17, 2022 Hello Yes I am talking about the siding. I didn't know the english word.. 😉 Thank you for the advice. Only it looks very difficult remove... 😅 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted July 17, 2022 Share Posted July 17, 2022 If you have access to a hand sander perhaps you could sand it down to a point where the spackle or joint compound will cover it. Quote Link to comment Share on other sites More sharing options...
hubfd Posted August 12, 2022 Author Share Posted August 12, 2022 Here is a picture of the process... It turned out better and cleaner then I had thought. A lot of work, but I'm about halfway! 2 Quote Link to comment Share on other sites More sharing options...
hubfd Posted August 12, 2022 Author Share Posted August 12, 2022 I also removed the porch. It will become a balcony instead. 3 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 12, 2022 Share Posted August 12, 2022 Looking good, Huberine. Quote Link to comment Share on other sites More sharing options...
chatoiement Posted September 18, 2022 Share Posted September 18, 2022 How exciting! It's coming along wonderfully, Huberine! 😊 Quote Link to comment Share on other sites More sharing options...
