Billie R. Posted July 19, 2021 Share Posted July 19, 2021 1. What is the name of that sticky tacky gummy stuff used to stick things down, up, around??? I need to order some. 2. If I connect a flickering fireplace to my electrical will it make the whole works pulse like my old tape wired house?? This time I'm hard wiring using a power strip. Many Thanks and I hope I don't annoy anyone asking these dumb questions HERE!!! Quote Link to comment Share on other sites More sharing options...
grazhina Posted July 19, 2021 Share Posted July 19, 2021 There's museum wax, which I don't care for, though others like it. I usually prefer Glue Dots, which are small clear silicone type discs, or Scotch Adhesive Putty. Mine is white, but I know I've used some pink, don't know if it was by Scotch or some other company. Can't help with the electrical question, haven't fooled with wiring much. Quote Link to comment Share on other sites More sharing options...
Kells Posted July 19, 2021 Share Posted July 19, 2021 41 minutes ago, Billie R. said: 1. What is the name of that sticky tacky gummy stuff used to stick things down, up, around??? I need to order some. 2. If I connect a flickering fireplace to my electrical will it make the whole works pulse like my old tape wired house?? This time I'm hard wiring using a power strip. I use museum wax to hold small accessories in place. Apply a small dab with a toothpick and use the absolute minimum you can get away with. Be warned it can discolor wood, sort of like a water ring. Or at least create a cloudy sort of look on the finish. It also leaves an oily mark on wallpaper. Never a problem for me because that area will always be covered by something. If you're placing something permanently, you may as well use glue. Flicker units only pulse all lights if connected to the main run of a copper tape wiring system. They interrupt the power flow to create the flicker, thereby interrupting the current to everything else connected to that run. If you're plugging hard wire into a power strip, it should work just fine. I've done it and it didn't cause anything else to flicker. You should not have to plug it into a separate power strip. If you do encounter a flickering problem, however, that's your fix; just use a different power strip for anything that flickers. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted July 19, 2021 Share Posted July 19, 2021 Billie, there are only dumb questions if you don't ask them. 1 Quote Link to comment Share on other sites More sharing options...
Kells Posted July 20, 2021 Share Posted July 20, 2021 On 7/19/2021 at 10:23 AM, havanaholly said: Billie, there are only dumb questions if you don't ask them. As my grandmother always used to say, "There are no stupid questions, only stupid answers." HAHA 1 Quote Link to comment Share on other sites More sharing options...
steiconi Posted August 1, 2021 Share Posted August 1, 2021 The flicker can be annoying if you want steady burning lights, but it's great for candles! Quote Link to comment Share on other sites More sharing options...
