IndyCindy Posted July 13, 2021 Share Posted July 13, 2021 My Aster cottage finally has a thatched roof. I used coconut fiber and basically followed the tutorial offered by Earth and Tree. I'm satisfied with the results, but I'm noticing LOTS of shedding. Today I was brainstorming ideas to help with the shedding and I wondered if a heavy coat of hairspray might work? Is this ridiculous? Will it not age well if I introduce something synthetic to the natural coconut fibers? Any suggestions and advice are welcome! Quote Link to comment Share on other sites More sharing options...
KathieB Posted July 13, 2021 Share Posted July 13, 2021 Hairspray holds natural fiber cloth to shape without yellowing or otherwise changing its appearance. I do not know why it would not work as well on the coconut fiber. It is invisible when it dries. 1 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted July 14, 2021 Share Posted July 14, 2021 Since hairspray is basically a water-soluble lacquer the only other suggestion I'd offer is to paint it with lacquer, several coats whichever you use. Quote Link to comment Share on other sites More sharing options...
KatFord Posted July 14, 2021 Share Posted July 14, 2021 I just did the Aster Cottage with coconut fiber. I used watered down pva glue in a spray bottle and after it was done I lightly sprayed it into the "roots" and over the top. I used a paper towel to dab off the drops of glue. It's held well no shedding. Kim 1 Quote Link to comment Share on other sites More sharing options...
IndyCindy Posted July 14, 2021 Author Share Posted July 14, 2021 12 hours ago, KatFord said: I just did the Aster Cottage with coconut fiber. I used watered down pva glue in a spray bottle and after it was done I lightly sprayed it into the "roots" and over the top. I used a paper towel to dab off the drops of glue. It's held well no shedding. Kim Perfect! Thanks for sharing your knowledge! 1 Quote Link to comment Share on other sites More sharing options...
