Vett Posted May 2, 2021 Share Posted May 2, 2021 I saw a video on you tube building a dura craft doll house and using a template to make stone on the house is there any place i can get this I dont see it on the website Quote Link to comment Share on other sites More sharing options...
havanaholly Posted May 2, 2021 Share Posted May 2, 2021 (edited) Bromleycraft products are reusable, with a spray adhesive. The Majic Brik/ Stone stencils were paper and you had to time things so you could remove them before the moisture from the compound made them too soft, but after the compound had set up a bit. I use spackle or joint compound and carve my "stones" into the damp material with a pointed toothpick: Edited May 2, 2021 by havanaholly Quote Link to comment Share on other sites More sharing options...
Vett Posted May 2, 2021 Author Share Posted May 2, 2021 Thanks but the only problem is not in the US Quote Link to comment Share on other sites More sharing options...
Muriel Posted May 2, 2021 Share Posted May 2, 2021 A couple other brick ideas: I printed and cut a stencil out for brickwork, then spray painted using textured spray paint for this house The conservatory bricks were made with egg carton torn in to brick shapes. Quote Link to comment Share on other sites More sharing options...
Muriel Posted May 2, 2021 Share Posted May 2, 2021 Sorry, better picture Quote Link to comment Share on other sites More sharing options...
Vett Posted May 2, 2021 Author Share Posted May 2, 2021 Looks nice Quote Link to comment Share on other sites More sharing options...
fov Posted May 2, 2021 Share Posted May 2, 2021 5 minutes ago, Vett said: Thanks but the only problem is not in the US Bromley Craft is in the UK but they ship internationally. The Magic Ston Holly mentioned is available at various miniature shops and eBay (do a search for "Magic Ston" and don't let Google correct it to "stone" for you!) Here's one listing for it: https://www.justminiaturescale.com/Magic-Ston-4-Sq-Ft-White-P14977.aspx This blog post shows my experience with Magic Slat (slate), which is the same concept: https://www.emilymorganti.com/blog/?p=12469 I often make stone out of egg cartons. I have several posts about it on my blog: https://www.emilymorganti.com/blog/?tag=egg-carton-stone Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted May 2, 2021 Share Posted May 2, 2021 Hi Fred, You can also use a stone template and drywall compound https://www.amazon.com/CrafTreat-Stone-Background-Stencil-x6/dp/B0756FPVCT Also, Paperclay makes awesome stone and brick. https://livingtheminiaturelife.blogspot.com/2019/05/paper-clay-bricks-quick-and-easy.html Quote Link to comment Share on other sites More sharing options...
Vett Posted May 2, 2021 Author Share Posted May 2, 2021 thanks thats what im looking for Quote Link to comment Share on other sites More sharing options...
havanaholly Posted May 2, 2021 Share Posted May 2, 2021 34 minutes ago, Vett said: Thanks but the only problem is not in the US Somebody (preferably Dawn) tell me, does Dawn no longer carry Bromleycrafts? Quote Link to comment Share on other sites More sharing options...
Thimble Hall Posted May 2, 2021 Share Posted May 2, 2021 I bought some stencils for cobbletone,patio stone, and bricks in three scales off Etsy a couple of weeks ago.The seller was Miniminutia.They came with full instructions for using them plus there is a link on the brochure for a youtube video may Quote Link to comment Share on other sites More sharing options...
Vett Posted May 2, 2021 Author Share Posted May 2, 2021 Thanks I'll check it out Quote Link to comment Share on other sites More sharing options...
Thimble Hall Posted May 2, 2021 Share Posted May 2, 2021 I am not sure what happened there, halway through typing I lost my page and I see the video shows not the link, anyway to repeat, I bought 3 scales 1/12 1/24 1/48of stencils,and three types ,cobblestone,patio stone and bricks on Etsy from Mini Minutia , they came with a brochure shwoing how to use then and a you tube link. she suggests Bromley stuff but it is exoensive to ship so another suggestion is Sanded grout from the hardware store, it apparently comes in many colors..and also spackle is a sugestion,hope this is of some use to you..sorry for the mix up. Quote Link to comment Share on other sites More sharing options...
Vett Posted May 2, 2021 Author Share Posted May 2, 2021 No problem, thanks Quote Link to comment Share on other sites More sharing options...
havanaholly Posted May 3, 2021 Share Posted May 3, 2021 We had a discussion several years ago about stencils and Bromley, I believe someone wanted to use it for brickwork. Anyway, one member made quite serviceable brick stencils from a middling large grid of plastic needlepoint scrim, cutting out alternate bars to get the brick gridI wonder if using something like the plastic mesh from a bag of fresh produce and a spray adhesive would work for your stencil; you can use spackle, joint compound or drywall "mud". 1 Quote Link to comment Share on other sites More sharing options...
Test Posted May 4, 2021 Share Posted May 4, 2021 Bromley brick and stone stencils and powder are available in the US at “Dolls and Minis” in Ohio. I recently placed a reorder. The owner is fantastic to work with and ships quickly. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted May 4, 2021 Share Posted May 4, 2021 THAT's Dawn, and she's a member here! Thank you, Heddy! Quote Link to comment Share on other sites More sharing options...
