Michael L Posted February 2, 2021 Share Posted February 2, 2021 So I’ve built my first dollhouse and I’m starting to wire it. I’ve got the transformer attached and the first strip of tape wiring works fine. But as soon as I try to attach a second strip with eyelets, the second strip doesn’t get power? Is there a common problem I’m missing? Copper is matched with copper and blue with blue, eyelets in the center of where each strip intersects. Help! Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted February 3, 2021 Share Posted February 3, 2021 Is there room at the connection to add more eyelets? If so, add some more. The copper must not be getting enough contact. Tip: I avoid making connections by mitering the tape...fold it back on itself. I also run my tape up to the next floor by cutting a slit and feeding the tape through. . 1 Quote Link to comment Share on other sites More sharing options...
