Tinyroomartist Posted December 28, 2020 Share Posted December 28, 2020 Hi! I'm new at this and am working with cigar boxes. I wasn't sure where to find like-minded people and, although I am not working strictly to scale, there is so much beautiful work here that I wanted to take a moment to thank everyone for the inspiration and also for the help I have already received! I hope I will be able to help others in some small way as time goes on . . . the photo is of a work in progress. The walls are foam core and I am trying to decide how to finish the edges. I am also perplexed as to how to finish the edges of the carpet so it looks nice (carpet is in the front room.) The wood columns on the right and left will need work, too. Not sure how detailed I want to make them. I'm building a little crystal chandelier to go in side the room, past the arch and will mirror the wall to the left, in the exterior of the lobby. The window is wax paper right now and that needs to be improved! What do others use for frosted glass? The box is 4" x 6". I want to make a little upholstered bench for the interior or maybe a little table with a guest book on it . . .or an elegant potted plant - something to peer into the archway to look at. 1 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted December 28, 2020 Share Posted December 28, 2020 Welcome to the little family, Diane. When I stitch carpets I blanket-stitch around two threads outside of the graph and run a bead of fabric glue around the underside before cutting the carpet free of the rest of the fabric I've stitched it on. I use clear acetate flat packaging to cut window inserts, and if I want it frosted I rub both sides with nail polish remover on a cotton ball; some super glues will also frost and texture the plastic, although you need to use one that won't melt it. Baker's parchment paper might also work. You could use seam binding or paper to finish the edges of your foam core. 1 Quote Link to comment Share on other sites More sharing options...
KathieB Posted December 28, 2020 Share Posted December 28, 2020 3 hours ago, Tinyroomartist said: What do others use for frosted glass? I've never used it myself, but I've always thought the frosted-look bags inside the cereal box would make great frosted windows. 1 Quote Link to comment Share on other sites More sharing options...
fov Posted December 29, 2020 Share Posted December 29, 2020 You can use vellum paper over plexiglass for frosted glass. Here's an example: https://www.emilymorganti.com/blog/?p=6214 I used paper with a pattern for an etched look, but if you don't want a design you can use plain vellum paper. 1 Quote Link to comment Share on other sites More sharing options...
Tinyroomartist Posted December 30, 2020 Author Share Posted December 30, 2020 I found some plastic packaging today cast off in our apartment building - clean and it is perfectly clear. I can try attaching wax paper to it or the vellum paper solution. It may substitute for plexiglass and be easier to cut. Has any one else used "upcycled" materials? Quote Link to comment Share on other sites More sharing options...
havanaholly Posted December 30, 2020 Share Posted December 30, 2020 Unless you have vellum on hand baker's parchment is easy to find. 1 Quote Link to comment Share on other sites More sharing options...
