Rin LeeSong Posted October 7, 2020 Share Posted October 7, 2020 I have dollhouse and I want to remake it because now I have to skills to make it look better I had used wood glue to put my dollhouse together I don’t really want to use tools like Hamas and things I would appreciate it if someone can give me some tips Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted October 7, 2020 Share Posted October 7, 2020 A heat source like a very hot hair blow dryer or an actual heat gun might help loosen the bond. You would also need a putty knife. And, a lot of elbow grease! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 8, 2020 Share Posted October 8, 2020 Sometimes a hammer with a light touch can assist that putty knife. Do wet the join/ seam with a damp rag to help the heat soften it; I read that a steam iron can help. Quote Link to comment Share on other sites More sharing options...
KathieB Posted October 8, 2020 Share Posted October 8, 2020 On 10/7/2020 at 6:28 AM, Rin LeeSong said: I had used wood glue If heat alone doesn't do the job, try soaking with vinegar to soften the glue. Heat and vinegar with help from a putty knife ought to loosen the joints sufficiently to pull apart. Quote Link to comment Share on other sites More sharing options...
Sable Posted October 8, 2020 Share Posted October 8, 2020 Xylene with the proper precautions will remove it in an instant. Quote Link to comment Share on other sites More sharing options...
