Abbie Posted September 18, 2020 Share Posted September 18, 2020 (edited) I purchased a put together Alexandria dollhouse so all I have to do is repaint the exterior and paint the interior and DECORATE! My questions is I would like to remove the front door. It opens and closes on a tiny pin but is in really bad shape. There is not any space to get some small snippets in there to snip the pin. Any ideas on how to remove the door. Thank you for any advice. Edited September 18, 2020 by Abbie Quote Link to comment Share on other sites More sharing options...
fov Posted September 20, 2020 Share Posted September 20, 2020 Is the door a kit door that has been pin hinged, or is it one of the Houseworks doors? If it has a separate frame (like a Houseworks door) you could try popping out the whole thing. Otherwise, if you can't cut the pins, you might need to destroy the door to get it out, and then replace it. If you wiggle the door around near the pins you might be able to splinter the wood enough to free it from the pins. Or you could get aggressive and punch it. Quote Link to comment Share on other sites More sharing options...
Medieval Posted September 20, 2020 Share Posted September 20, 2020 If you're not keeping the door I would cut it in half [horizontal cut] and then pull it free. A Drexel tool can make the cut, a small hand saw, or some good clippers maybe. Quote Link to comment Share on other sites More sharing options...
Medieval Posted September 20, 2020 Share Posted September 20, 2020 Dremel* not drexel. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted September 23, 2020 Share Posted September 23, 2020 If the door is in bad shape, I'd go ahead as others have suggested and destroy it to remove it, and the pins. Quote Link to comment Share on other sites More sharing options...
Abbie Posted October 2, 2020 Author Share Posted October 2, 2020 Thanks to all.....pulled and tugged and slightly splintered the top of the edge....edge of the hole for the door to fit in but I’m planning to replace it with a pre put together door with trim....I think that will work! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 2, 2020 Share Posted October 2, 2020 If the door is too big you can trace around it over the opening and carefully shave away the excess to make it fit, and if it's too small you can place it in the opening and shim it with bits of scrap wood or cardboard. Quote Link to comment Share on other sites More sharing options...
Medieval Posted October 2, 2020 Share Posted October 2, 2020 23 minutes ago, havanaholly said: If the door is too big you can trace around it over the opening and carefully shave away the excess to make it fit, and if it's too small you can place it in the opening and shim it with bits of scrap wood or cardboard. I wish I had know this....but I will use it in the future. I was too big and not careful in reducing and now I'm too small and adding bits....there's a lot to be said for experience! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 2, 2020 Share Posted October 2, 2020 That's why I advise people paralyzed by a craving for perfection the first time to consider mistakes as learning opportunities. Why else did God place our ears so conveniently to hang eyeglasses off of? Quote Link to comment Share on other sites More sharing options...
