A fact about building stairs
I thought I'd bring this up, since a lot of people are confused about building stairs. I'm no expert, but I've built a few, and I've just been working on another one for my 1:24 cottage row. Both of these staircases are the same height. Please excuse the irregularity of the one I cut from builders' foam. I was experimenting and planned on encasing it from the beginning, so cutting errors wouldn't be visible anyway. The second one was made from a piece of balsa stripwood. The foam staircase risers are based on a height of 5/16", but when I went to start the second staircase, I didn't happen to have the right sized wood, so I used 1/4" for the risers. As a result, although both staircases are the same height, one has 12 steps, the other has 17, and as a result is over 1" longer. The size you use for treads and risers makes a big difference. I always use the measurements of my stairs at home and proceed from there.
In the White Orchid, the stairs were carved out of contractor's foam in one solid piece. See it here.
The lights in this build operate from a battery pack, which is hidden  in a carved out section behind the stairs. The bottom section of stairway slides out for access.
I love that there are so many very different ways to approach a project in miniature.
Nice!
