Wildfordollys Posted August 23, 2020 Share Posted August 23, 2020 Hi, I am about to put new wallpaper in my already built dollhouse— do I have to remove windows/window trim first? Any advice would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
KathieB Posted August 24, 2020 Share Posted August 24, 2020 Removing the trim would be the best bet for a nice, clean result. However, if the trim is too hard to remove, you could try using tissue paper pressed against the wall to create a template so wallpaper can fit around the window/door trim. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 24, 2020 Share Posted August 24, 2020 Templates. Quote Link to comment Share on other sites More sharing options...
Medieval Posted August 24, 2020 Share Posted August 24, 2020 Or use sticky notes that overlap and tape down edges to make one sheet that you can fit around windows and doorways. Quote Link to comment Share on other sites More sharing options...
Sable Posted August 24, 2020 Share Posted August 24, 2020 I generally strip the entire house of windows, trim and wallpaper. Then I take the house outside, give it a good cleaning and spray paint the entire house with Kilz primer. A clean slate helps with my creativity. In my case, I’ve always purchased new windows And sometimes changed the openings so pulling the old ones off was not a problem. Quote Link to comment Share on other sites More sharing options...
Wildfordollys Posted August 24, 2020 Author Share Posted August 24, 2020 Thank you everyone for your advice!! Quote Link to comment Share on other sites More sharing options...
Wildfordollys Posted August 24, 2020 Author Share Posted August 24, 2020 Hi again—-Havanaholly, could you please tell me what’s involved in making templates for rewallpapering an already-built house? I really have no idea on how to proceed; This is so new to me! Quote Link to comment Share on other sites More sharing options...
Darla Posted August 24, 2020 Share Posted August 24, 2020 Hi Kathryn - I found a wonderful video series on youtube "My Dolls House Diary" posted by Julie Warren. She shows you how she updated her doll house including how she took the paper off and then how to make templates for wallpapering. There are a couple of dozen videos in the series and they jump around a little bit. I believe the wallpaper instructions are in one of the kitchen videos. Good Luck! Quote Link to comment Share on other sites More sharing options...
Wildfordollys Posted August 24, 2020 Author Share Posted August 24, 2020 Thanks!!!! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 24, 2020 Share Posted August 24, 2020 Jess suggested Post-It notes, but you could use any smallish pieces of scrap paper and transparent tape and lay the pieces along your wall to make the template/ pattern of that wall with any door or window openings. When you lay your piece of wallpaper over the wall do allow at least 1/4" on each end to wrap the inner corners. Lay your wallpaper on your cutting mat, lay your template centered on top of your wallpaper and carefully cut out any door or window openings. I would probably apply the wallpaper paste to the wall and lay the piece of wallpaper onto the wall with the openings perfectly aligned, and carefully smooth the wallpaper out to the edges. Quote Link to comment Share on other sites More sharing options...
Medieval Posted August 24, 2020 Share Posted August 24, 2020 Ha holly! That is actually how i lay out and cut out wallpaper for my walls when they are not already installed. I thought sticky notes would help with walls already standing and especially in hard to reach spots. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 25, 2020 Share Posted August 25, 2020 Whatever does the job; not all of us have Post-Its. Quote Link to comment Share on other sites More sharing options...
Mineejv Posted August 25, 2020 Share Posted August 25, 2020 When I remodel a houseI I use newspaper for my templates for the wallpaper. I put the top straight edge and the side straight edge into a corner, I crease the other Corner and the bottom with my finger. If you’re going to wrap your corners just add a 1/4 of an inch to each side when you cut. I’ve found that some rooms are square some are not... so I always go by my template. Quote Link to comment Share on other sites More sharing options...
