grannybaby0119 Posted August 11, 2020 Share Posted August 11, 2020 I am having trouble assembling the 1st floor in the Fairfield doll house can someone help me. The tabs are not matching up. Quote Link to comment Share on other sites More sharing options...
Medieval Posted August 12, 2020 Share Posted August 12, 2020 I've never done the Fairfield but did you make sure all the parts are facing the proper way? For example the exterior is facing outward. The floor is facing up? It sounds silly but I noticed my Pierce only goes in one direction. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 12, 2020 Share Posted August 12, 2020 The plywood has a smoother side and a rougher side, if that's any help. Quote Link to comment Share on other sites More sharing options...
fov Posted August 17, 2020 Share Posted August 17, 2020 If you're sure the pieces are facing the right way but the tabs still don't match up, if they're only a little bit off you can cut down the tabs or enlarge the slots with a utility knife. Quote Link to comment Share on other sites More sharing options...
mertaireorf Posted December 1, 2020 Share Posted December 1, 2020 I am having trouble understanding the chimnel wall. The instructions say to place on the left side, aligning with the top slot of the chimney...which is left? and the only slot I see doesn't seem to match up. Quote Link to comment Share on other sites More sharing options...
Call Me Crazy Posted December 2, 2020 Share Posted December 2, 2020 15 hours ago, mertaireorf said: I am having trouble understanding the chimney wall. The instructions say to place on the left side, aligning with the top slot of the chimney...which is left? and the only slot I see doesn't seem to match up. Hi Art! I tried to find a good photo of the chimney with the wall to show you how it should look. This photo came from moreminis.blogspot.com - which is a great resource and I highly recommend you look through her two Fairfield builds. The verbiage of the instructions assumes that the front of the house is always facing you. Hold the "Left Chimney Wall Extension" up as seen in the schematic so it looks sort of like a T. The top projections of the T slot into the big center wall and the left side of the chimney (see photo). The tab on the bottom of the T slots into the floor. *If you built your chimney without a slot for the wall to fit into, you could trim the wall to be flush with the chimney side instead. As long as it slots into the center wall, the foundation and the 2nd floor, it will stay in place just fine. Feel free to DM me if this is still confusing. Quote Link to comment Share on other sites More sharing options...
