whoistono Posted August 12, 2020 Share Posted August 12, 2020 Hi does anyone have this house? Cassi Dollhouse Kit by House That Jack Built This is my first dollhouse. What do you do first the shingles, siding or trim? The instructions say hot glue but I don't want to use hot glue. What glue do you use? Can you show me pics/videos of your house? Thank you. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted August 12, 2020 Share Posted August 12, 2020 Welcome Janet, Use wood glue, and is this house also nailed together? I have a different kit from the House that Jack built and small pin nails are also used in the assembly. Wood glue is much stronger than nailing alone. The shingles can be done at any time once the structure is complete. Quote Link to comment Share on other sites More sharing options...
whoistono Posted August 12, 2020 Author Share Posted August 12, 2020 Hi the house is nailed and glued. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 12, 2020 Share Posted August 12, 2020 Hi, Janet, is the house pretty much already together, like in the photo? If so, I wonder if those porch railings & posts could be carefully removed, or siding that beast will be a bear, much less painting it; and I always wait to install the windows and doors last thing, after all of the interior and exterior decorating is finished, so as not to get house paint on the trim or trim paint on everything around, or any paint on the clear part of the windows. Quote Link to comment Share on other sites More sharing options...
fov Posted August 13, 2020 Share Posted August 13, 2020 My parents built this dollhouse for my niece several Christmases ago. You can see pictures here: I think their kit had siding milled into the walls. In that case you don't have to worry about the siding since it's been done for you. If your kit has smooth walls, then I suggest you build the shell (but not the porch), add siding, add windows, and then finish the porch. You can do the shingles at any point once the roof is installed but I usually save them until near the end of the build. Quote Link to comment Share on other sites More sharing options...
whoistono Posted August 14, 2020 Author Share Posted August 14, 2020 (edited) The dollhouse was given to me it was already made. The sides are smooth. We are in the process of removing the shutters and windows and the door so we can put the clapboard siding on. They attached the porch already so will need to work around that area. FOV I loved your dollhouse. Edited August 14, 2020 by whoistono Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 14, 2020 Share Posted August 14, 2020 Janet, seriously try to remove the posts and railings from the porch, if you can, before trying to put siding on that area. If it were me I would cover the window & doors trims with masking tape and stucco the exterior with spackle or joint compound. Quote Link to comment Share on other sites More sharing options...
whoistono Posted August 14, 2020 Author Share Posted August 14, 2020 The porch doesn't having any railing only 4 post. It should be hopefully easy to do the front once the windows and shutters and door is off to do the siding. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 14, 2020 Share Posted August 14, 2020 When you said it was already built I thought that would have included the porch railings. Lucky youl, siding ought to be a lot easier, then! Quote Link to comment Share on other sites More sharing options...
