I have recently acquired a amazingly beautiful doll house for FREE, hard to believe, but it's true. There are a few cosmetic issues on the exterior that need replaced and/or fixed: The entire porch railing. Most of the clear plastic window backings are missing. Doors need it be replaced. Trim work needs to be replaced, and from what I can tell, a balcony/walkway of some sort existed above thw3rd floor window and wrapped around  both sides of the house. I want to restore & repair it to prime condition & do it correctly.
I was never lucky enough as a child to have one of my own. So this is a very special project for me to say the least, lol.
I have no information on it what so ever & would really like to figure a few things out about it, if possible:
¹What particular kind of doll house it? ²How old is it? ³What can be DIY/hand-made instead of buying expensive pre-made kits, like porch railing, banisters ect? ⁴Is it possible to add a balcony to the 2nd or 3rd floor? ⁵Is it possible to modify an existing window into a doorway? ⁶Is it possible to add/remove interior walls to make rooms/areas bigger/smaller? ⁷Can a door be added to an existing interior wall? ⁸Can a 2nd door leading to the porch be added on the side of the house?
I have no clue and figured the best thing to do was ask.
ANY tips & advice on the best way to go about any of this would be greatly appreciated!
My ultimate goal is to completely restore & repair the entire doll house top to bottom.
Hi, Jessica, and welcome to the forum. As to your questions, the answer is yes. Taken together they may seem overwhelming, but taken one step at a time, it is all do-able. Our administrator Tracy (Minis on the Edge) has a mantra: It is hard by the yard but a cinch by the inch. Feel free to ask for advice on specific parts of the renovation.
Welcome to the little family, Jessica.  I have requested that this topic be moved to the Newcomers' Forum, since this one is primarily for technical questions about the website.  What a gorgeous house!  One of our more knowledgeable members (Kelly!) most likely can better answer your first two questions.
...¹What particular kind of doll house it? ²How old is it? ³What can be DIY/hand-made instead of buying expensive pre-made kits, like porch railing, banisters ect? ⁴Is it possible to add a balcony to the 2nd or 3rd floor? ⁵Is it possible to modify an existing window into a doorway? ⁶Is it possible to add/remove interior walls to make rooms/areas bigger/smaller? ⁷Can a door be added to an existing interior wall? ⁸Can a 2nd door leading to the porch be added on the side of the house?...
#3  Anything and everything can be handmade with patience and a few simple tools & supplies.  Big box craft stores like Hobby Lobby have a section that carries basswood in sheets and strip wood.  A Stanley box cutter with retractable blades will cut basswood up to 1/4" thick, invest in lots of new, sharp blades.  The plastic from report covers or flat packaging (like the clear acetate boxes that Pepperskins long johns comes in)make excellent replacement window panes.  Take a look at the album where I received a Greenleaf Laurel that was falling apart and I had to finish disassembling it, rebuild it, make a new wrap-around porch (I didn't bother with the railing, I made it to donate) along with doors, windows and furniture.  I used strips of chamois (detailing rag from the auto parts store) to hinge the doors and one working window.  Now when I build kits I make stripwood boxes to fit inside the door and window openings and pin-hinge the doors with dressmakers' steel pins:  http://www.greenleafdollhouses.com/forum/?app=gallery&module=gallery&controller=browse&album=7565
#4  Of course you can add a balcony, a conservatory with a roof garden, or anything you can imagine.
#5  On an already built house it's tricky, but of course you can make doors out of windows.  It's easier if you can remove the wall, which should also answer questions #6, 7 & 8.
If the interior is decorated you will want to strip out the old wallpaper, since wall removal & repositioning will probably damage what's there; ditto floors, baseboards, etc.  BTW, this is what we refer to as "bashing" when we're discussing dollhouse renos.  Invest in a good carpenters' wood glue and a cork-backed steel ruler (for cutting straight lines with your box cutter utility knife) and enjoy the ride.  IMO this forum exists to assist in answering questions about building/ bashing dollhouses. and other mini-related topics.
  • Like 3
  • Similar Content
    • By AlisonJR
      Hello!
      I'm currently working on my first dollhouse. I bought this already assembled and have noticed there are hinges in the corners of most of the rooms (photos attached) some of which stick out quite  bit. I am wondering if anyone has suggestions for how to hide these as I don't want them to show under my wallpapers. (it seems as if they were used to pull the corners of the dollhouse walls together)
      Thanks!
    • By AlisonJR
      Hi,
      I am currently working on my first dollhouse. It is an Alison Jr. I am hoping to handpaint and illustrate my own wallpaper and am not sure where to start. What paper is recommended? Also wondering if a seal, specific glue is required. I was hoping to make individual entire wall sized paintings (probably with watercolour paint) that will mount to the walls as wallpaper (and won't fade over time).
    • By jenr627
      I have built a bunch of mini homes but I think the last one I did was over 4 years ago.  I really want to get back into it, I have tons of kits that I have great ideas for but I am feeling a little panic.  I just have not done this in so long I feel like I am going to screw it up somehow.  Starting with a Buttercup cottage for a 4 year old relative.  Looking for some good tips and maybe a few words of encouragement!
      Thanks!
      Jen in NJ
    • By Minis On The Edge
      So, Monday morning started like all the others. I started writing down things I had to do this week because it was gonna be a busy week full of appointments. Around 11 am I got a email from a friend from the Greenleaf forum. Emily told me that one of my houses that I sold years ago was on Craigslist in Wisconsin. At first, I pictured it to be one of my earlier houses  before I was using paper clay. I pictured it to maybe one from when I first started out because I sold a few of those here in Wisconsin and Illinois. I clicked the link and was surprised because it was the McKinley dollhouse kit that I built for the Greenleaf construction blog!!   How did that get here from California?!! I sold it to a lady who lived in California in 2008. I remembered a couple of years ago seeing it on eBay. So, I said to myself “before you get excited, send them a message.”  The  listing had been “Live” for 11 days and it looked like a thrift/charity store.  I sent the message and then decided to look them up and call instead of waiting for an email reply. The store was a little over 2hrs away from me. I called and asked about the dollhouse listed on Craigslist.  My name was signed on the back of the house so he began to tell me about how it was dropped off in the donation center with a box of other related things.  He kept talking about it’s a nice solid built dollhouse. He said he don’t know who Tracy Topps was but that the person dropping it off said he’d come back with more dollhouse stuff he had to get rid of! So finally I asked, was the dollhouse still there, and he said yes it was! I had to pay over the phone because they couldn’t hold it for me otherwise. I told him I was Tracy Topps and I had built this and shipped it to a lady in California 11 years ago! He got excited then and said well now I want to know how it ended up back here and how did you find out since you live so far away from here. So we chatted for a little bit longer. I wanted to go get it Monday so badly because I was worried it might be gone when I got there or damaged more. I got there and it’s still pretty solid. Some shingles are missing or paint is scuffed off. It’s dusty and the insides are scuffed and damaged a little. The staircase and fireplace had been removed and damaged and the lighted fire  doesn’t work in it. Several other lights are missing or broken too. I haven’t checked to see what’s working or not because once again, I have errands to run. But, when I got home, I opened the 3 drawers below the house and discovered several dolls and other things along with the box of furniture that has some things from Rhuetter Porcelain & Heidi Ott. A few of the dolls are by Detta’s Darlings (eBay name) some things I’m not sure who made. I got this all for about $100 including a tank of gas! They were just all happy it found it’s way back to someone who could clean it up and fix it. I think several people who worked there didn’t even know it was there because they all were saying how nice it was and asking each other where was it at in the store and how much was it sold for when it made its way to the front of the store. I never find dollhouse bargains at thrift stores EVER  so finding my OWN dollhouse was exciting, but finding all this other stuff was really a treat!! I’m not sure what I’m gonna do with it yet. I’ll decide as I restore it  but that’s the story of Stone Brair dollhouse (Which was the name we gave it back then and it’s signed as that on the back   you can see my photos of some of what I got by clicking here  https://flic.kr/s/aHsmJNPf1h Thank you Emily for letting me know and Thanks to Carmen who told her about it! I’m so EXCITED to have this back!
    • By third_hand
      Hi everyone! I've had a long quiet period on here, but I've been steadily working away and going to shows/shops (I was at Good Sam in San Jose and was fortunate to visit Dollhouses, Trains, and More in Novato, CA for their closing sale). I will, finally, post a batch of haul and progress photos in the first week of November, when I get settled back into my home in Eugene. I really am terrible with a camera and it bugs everyone I know! In the meantime, I have a question:
      Has anyone ever tried adding siding after their build's exterior was complete? Still being a novice, when I finished my first build (the Orchid; the interior is still a work-in-progress) I stepped back and thought 'I think I should have done siding.' Especially with the shingles on, the level of detail on the exterior just varies too much; it's been irritating me for a couple of months now. I'm a bit of a stickler it seems (though I didn't know it at the time)! My window/door casings, dormers, gingerbread, and my custom porch/railings are all already in place. I realize it may be very difficult, but the question is: is it even possible? If so, do you have any tips on how to do this?
      Any and all possible mini wisdom is welcome!
      P.S. I have the opportunity to snag a very affordable Laurel kit secondhand so I'm trying to decide where I should just start the next building with siding and call it 'lesson learned' or go back and add to the Orchid (and stash the Laurel until after the New Year, space is a very important consideration here). P.S. P.S.: I'm not a Cher fan, but I took a page out of Elizabeth's book (Studio E miniatures) since I'm always charmed by her ability to make musical jokes in her posts/titles!
