Medieval Posted October 18, 2019 Share Posted October 18, 2019 Evening! I washed my dusty, musty Pierce with a damp cloth rinsed in a bleach solution and have pieces of lump charcoal soaking up unwanted odors. As soon as it dries or next weekend I'm going to melt the hot glue and take it apart. My question is: should I trace where everything is now before I dismantle or should I dismantle and do a dry fit and mark where walls, etc go once hot glue is gone. Will there be a huge difference? Previous owner used quite a bit. Quote Link to comment Share on other sites More sharing options...
Sable Posted October 18, 2019 Share Posted October 18, 2019 I’d mark them now. Use a code system at each joint like A to A, B to B..... 2 Quote Link to comment Share on other sites More sharing options...
Medieval Posted October 18, 2019 Author Share Posted October 18, 2019 Excellent. Never would have thought about coding! Thanks! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 18, 2019 Share Posted October 18, 2019 You can always check your marks when you dry fit after removing all that hot glue. I also use the dry fit to adjust any tabs and/ or lots that might have swollen or otherwise gotten "off" because the original builder didn't bother to check. Also, if the glue oozed or dribbled out of the joins it might throw your trace lines off. 1 Quote Link to comment Share on other sites More sharing options...
