Sign in to follow this
worldofcrazies
Hurstwood Cottage Kitbash
Hi,
I've introduced myself in the newcomers forum.
I received my Hurstwood Cottage kit from Bromley yesterday and I've already started on it.
Here's an album of me unpacking it: https//imgur.com/a/1ITiW6m
This is an intro post basically. This is my first dollhouse build so I thought I'd go for a small one and my plan for this also includes doing three different types of exterior finish; brick, panelling and render.
I'm going to turn this into a nice modern home.
Now getting into it a little bit. I've already started to prime and paint the walls.
Here's a dry fit of the cottage: http://imgur.com/a/AdRl5m0
It fit together great, although there were some random extras included in the box that I'm not sure what to do with? Basically little triangles, I don't have a pic right now but I'll upload one later.
Here's some pics of me priming the cottage:
http://imgur.com/a/CMFfqzL
I used a wood primer/undercoat to prime the MDF pieces and I put it on with a roller.
Before using the white primer I used a grey auto spray primer which gave really good smooth coverage, I had it left over from some uni work. But since it's summer and my uni paint shop isn't open I couldn't find the same primer easily so I had to switch to another type ( the white).
Today I've done a few more coats:
http://imgur.com/a/lUczTtj
G2g but I'll explain these pics later.
Those triangular pieces look like maybe roof supports.
That's a cute little house! I found this interior picture on Bromley's website: https://www.craft-products.com/prodimages/large/BDH0512-4.jpg
The little triangles look like they're meant to attach the second floor ceiling to the peaked roof.
Oh, I just read in your introduction thread that this is 1:24 scale. My favorite scale. :)
That looks like a well-made kit.  You've got a nice start on it.  Looking forward to seeing more (and I love your little helper).
Sabrina, hang onto those little triangles; they might come in handy for decorative touches (roof beams to hang things from, for one).
Maybe those triangles are like for propping your piece on top of to paint - like a saw horse???? :dunno:
Thank you! I had no idea there was a second floor :,-). Also, so glad to know another person loves 1:24!!
And thanks everyone, for the nice comments.
I've done a bit more work now, first I had to sand off the primer from the edges for everything to fit again >.<. ( Next time I'll definitely just put masking tape on all edges). It took so much effort and time.
http://imgur.com/a/Bwi1uUz
And then I started on the exterior finishing, so I've started doing the panelling. I cut it all out of a sheet of .8 mm Balsasood (I also had Basswood but it felt a bit too soft). It also means the lines aren't super straight since I hand cut them.
http://imgur.com/a/6BC2AzN
Not sure if I should seal it, I'm thinking maybe PVA glue? Any ideas?
After I've done panelling I'm going to try and do the brickwork, either with the egg carton idea or with cork board - I'm just not sure if the corkboard texture will look to large for 1:24 scale.
Thanks for reading! I hope to reply more often.
17 minutes ago, worldofcrazies said:
...I had to sand off the primer from the edges for everything to fit again >.<. ( Next time I'll definitely just put masking tape on all edges)...
When I dry fit a house kit I go through with my pencil and trace along all the corners and mask those edges of the walls where I will glue the adjacent wall, thus gluing bare wood to bare wood.
20 minutes ago, worldofcrazies said:
...I've started doing the panelling. I cut it all out of a sheet of .8 mm Balsasood (I also had Basswood but it felt a bit too soft)...
Balsa is 'way softer than basswood.
21 minutes ago, worldofcrazies said:
...Not sure if I should seal it, I'm thinking maybe PVA glue? Any ideas?...
Stain will seal it, and you can always finish with a matte sealer.
Ah, maybe it was mislabelled then! Well whichever one was harder is working pretty well!
I don't want to stain the wood - I think it looks fine as it is. So I'm not sure what product to use to seal it so it's Matt and doesn't change colour..
Check your local hardware store for clear matte sanding sealer.
  • Similar Content
    • By Jesseblues89
      I have recently acquired a amazingly beautiful doll house for FREE, hard to believe, but it's true. There are a few cosmetic issues on the exterior that need replaced and/or fixed: The entire porch railing. Most of the clear plastic window backings are missing. Doors need it be replaced. Trim work needs to be replaced, and from what I can tell, a balcony/walkway of some sort existed above thw3rd floor window and wrapped around  both sides of the house. I want to restore & repair it to prime condition & do it correctly.
      I was never lucky enough as a child to have one of my own. So this is a very special project for me to say the least, lol.
      I have no information on it what so ever & would really like to figure a few things out about it, if possible:
      ¹What particular kind of doll house it? ²How old is it? ³What can be DIY/hand-made instead of buying expensive pre-made kits, like porch railing, banisters ect? ⁴Is it possible to add a balcony to the 2nd or 3rd floor? ⁵Is it possible to modify an existing window into a doorway? ⁶Is it possible to add/remove interior walls to make rooms/areas bigger/smaller? ⁷Can a door be added to an existing interior wall? ⁸Can a 2nd door leading to the porch be added on the side of the house?
      I have no clue and figured the best thing to do was ask.
      ANY tips & advice on the best way to go about any of this would be greatly appreciated!
      My ultimate goal is to completely restore & repair the entire doll house top to bottom.
    • By third_hand
      Hi everyone! I've had a long quiet period on here, but I've been steadily working away and going to shows/shops (I was at Good Sam in San Jose and was fortunate to visit Dollhouses, Trains, and More in Novato, CA for their closing sale). I will, finally, post a batch of haul and progress photos in the first week of November, when I get settled back into my home in Eugene. I really am terrible with a camera and it bugs everyone I know! In the meantime, I have a question:
      Has anyone ever tried adding siding after their build's exterior was complete? Still being a novice, when I finished my first build (the Orchid; the interior is still a work-in-progress) I stepped back and thought 'I think I should have done siding.' Especially with the shingles on, the level of detail on the exterior just varies too much; it's been irritating me for a couple of months now. I'm a bit of a stickler it seems (though I didn't know it at the time)! My window/door casings, dormers, gingerbread, and my custom porch/railings are all already in place. I realize it may be very difficult, but the question is: is it even possible? If so, do you have any tips on how to do this?
      Any and all possible mini wisdom is welcome!
      P.S. I have the opportunity to snag a very affordable Laurel kit secondhand so I'm trying to decide where I should just start the next building with siding and call it 'lesson learned' or go back and add to the Orchid (and stash the Laurel until after the New Year, space is a very important consideration here). P.S. P.S.: I'm not a Cher fan, but I took a page out of Elizabeth's book (Studio E miniatures) since I'm always charmed by her ability to make musical jokes in her posts/titles!
    • By hdatsopoulos
      Hello Everyone! I recently acquired not 1, but 2, Magnolia Dollhouse kits from Corona Concepts. My parents found the boxes tucked in the back of a closet when they moved into a new apartment. When they pulled the boxes out and realized what they were, I got really excited, because I love building dollhouses, and the Magnolia was one that I always toyed with buying. It was like Christmas in July! However, it looks like I’m missing pieces, that I will either need to build myself or reorder. I already know that I’m missing 24 of the 32 window sashes that I need. Let the building challenge begin!
    • By Stacy Nicole
      Hello,
      I stumbled upon a Newberg at a local thrift shop for $3 the other day & obviously couldn't pass bringing it home. It was spray painted pink, had glitter glue adorning the exterior window casings & the roof was a lovely sponge painted gold & purple -- OOF. Anyhow, I've repainted the exterior to mimic local Victorian home I'm in love with, but wanted to reach out for some suggestions to replace the missing trimmings for the arched window frames. Reframing the square frames was easy enough, I just used some bass wood from the craft shop, but for the curved frames I'm at a standstill. Would you suggest cardstock or mat board? I supposed  I could cut them all from wood, but it would be pricey & I'd likely ruin quite a few in the process.
      I'd also love some suggestions to add back the lovely gingerbread work to the window panes. I was thinking just adding the designs to some clear plastic with a paint pen...I've attached the house as it stands currently.
    • By dooder85
      Yet another wash over the bricks, and a base coat on the 'stones' around the doorway
