Gold Paint for Unfinished Wood Furniture
Hi All!
I’m a newbie when it comes to finishing miniature furniture. I have a lovely unfinished chair that has some carved detail and I’d like to repaint it gold, bronze, or dark brown and reupholster it. Can anyone recommend a brand and color of gold paint? In general, what are your favorite paint types and brands to use when painting miniature furniture? Do you prime the wood before painting? If so, what do you use.
Thanks in advance for your help!
Sylvia
Why gold or bronze?  Just because?  If it's going to pass for 18th Century French I'd prime and paint it white and use a gold Sharpie pen to pick out the details and haunt the thrift stores for white or off-white silk to reupholster with, and paint tiny floral motives on the seat and back.
1 hour ago, QuirkyNerdyCool said:
Thanks a lot, @Sable. Would you recommend Citadel for painting furniture other colors? For instance, dark brown?
Definitely. Since their paints are for very small models it doesn’t go on too thick. I borrow my son’s vast collection of them. I use the bronze for my faucets.
 Small cans of Minwax or Rustoleum stains are available at Home Depot and Lowe’s. Stir them well with a small stick, do not shake them. My personal preference is Dark Walnut but everyone has their own preference. Kona is the next darkest color.
I apply the stain with a paper towel, wait a minute or two and wipe off the excess. Let dry and sometimes I apply a water based polyurethane. You’ll have to decide on the type of sheen/gloss.
Minwax also comes in felt pens, which are useful for staining small items, trims, etc. They are not sold as refillable, but if you have a steady hand, the felt tip can be pulled out and stain from a can can be inserted.
Minwax is also my go-to.  I have a couple of pairs of reverse tweezers and I have been known to dip small parts into the can of stain.  For larger parts I use a piece of an old teeshirt I've cut up into rags.  The Habitat for Humanity ReStores are an economical source for stains.
I’m always forgetting about those great little pens.
I like that I can have a variety of shades on hand without having to store the cans. The pens last a fairly long time.
Thanks so much, @Sable, @KathieB, and @havanaholly. Your suggestion are so helpful. My local hardware store only had stain markers by Varathane. I tried the dark walnut on my chair. It came out way darker than I expected. I may have applied too much of the marker. The chair finish looks more like ebony and I’m totally okay with that.  I’ve attached a photo of some real ebony chairs that have a similar look as well as photos of my chair in progress. Would love to hear if you all have any suggestions on additional techniques for finishing/refining the wood stain.
I really like the way the color turned out. One thing about stain, it doesn't clog up the carvings. :)
I like Sable's suggestion to gently smooth out the ridges in the smooth sections of the chair. Also, try buffing with a piece of paper bag that has been crumpled to soften. It will highlight the raised bits with a lovely sheen .
  • 1 year later...
  • Similar Content
    • By My Miniature Madness
      Best Adhesive For Thin Wood Veneer?
      What is the best adhesive to use on thin wood such as shingles or veneer for flooring? I posed this question on the Greenleaf Forum recently, and the answers were as varied as the species of wood available.
      Some liked to use hot glue, but the drawback was the longevity and the fact that getting burned was common. Some liked to use rubber cement, but others pointed out that eventually it dries out and loses it's bond. Some said contact cement, but others reminded us that you only get one chance to position it correctly. Once it's touched to the other piece, you're out of luck. Also, the smell was terrible. Still others said regular wood glue, securely clamped until the glue cures. Yet some said they had bad experiences with wood glue not drying clear and wood still curling in spite of clamping. Then there was the super glue camp, also pointing out the mess and the expense.
      What this told me is that we've all experimented and didn't like some of the results with different products. But do we all have our favorites in spite of certain risks?
      I had a terrible time finding a good solution with Encounters Gifts & Grub. I had thin veneer strips from HBS that I wanted to use as clapboard, wainscoting and paneling. Plus, there were all of the shingles! I had a lot to do, and needed whatever it was going to be to work!
      I started out with Tacky Glue and quickly realized that the only way to prevent curling was to put a thin sheen of it across the piece then get it down immediately and clamp it. That's okay if you have a lifespan of 1000 years and can wait for glue to dry. Even the clamping quickly method sucked. When I lifted the clamp off I now had oozed glue to clean up. Tacky is not a good candidate for sanding, either.
      Then I tried contact cement. Oh it stuck! To me and everything else within a 10 foot radius. And, if you aren't a pristine crafter, you'll end up like me with little rubberized gobs sticking out between your seems. :0(
      I tried Quick Grab. I was just as messy with that. I couldn't get it applied fast enough! I'd put out a little squirt on waxed paper, try to get the cap back on quickly before the oozing became too incessant, then try to spread it on the wood before it became too crusty to stick. I always somehow ended up with it on my fingers and didn't realize it until I had touched something. At $7 for that tube I'd have needed to be a millionaire to get all my wood attached. <insert sad sigh>
      In my pout, head on the table, 1000 mile stare, I just so happened to look at my wallpaper paste. It was sitting at eye level. It said "A Stikflat Glue". What? Could it be?!? It was the one and only Grandmother Stover's. I've been using that on wallpaper for ever! And it makes other stuff stick flat? At this point I really had nothing to lose.
      I took an old paint brush and painted a nice, thin bead across the wood strip. I stuck it on the wall. It stuck. I stared at it for what seemed like a full week. I never caught it curling. After several cocktails hours, I tried to pry it off. Nope! It was not coming off! Success! I used it to glue the rest of my veneer without a problem. It was easy to wipe off any excess with water, dried clear, and over three years later is still holding on great! Plus, it's like $5, and goes a loooong way!
      Okay, so I thought I might get an answer from the collective genius of the forum. Some magic product I had never heard of, and it would change my life. Not so much. It seemed everyone was just as dissatisfied as I had been. So, for the Alki Point flooring, I decided to experiment again.
      I used what I had on hand, because I assume most miniature enthusiasts would have the same type of adhesives, too. Quick Grab Tacky Glue, Titebond Wood Glue (the clear drying kind), and good old Grandmother Stover's.
      I have a pack of very thin veneer to use on my project, so what better to experiment with. I cut several long and several short pieces using my rotary paper trimmer. I took a piece of the 1/8" plywood from the Greenleaf kit (cut out left over from window) to use as the gluing surface.
      Then I added the adhesives to the long and short pieces, and affixed them to the plywood scrap. I pressed each of them a few times, but didn't want to clamp them. What would they do on their own without any force over time?
      They have been drying for a couple of hours now, and the results are pretty much as I expected.
      The Quick Grab Tacky - dried with edges curling up
      The Titebond - Significant curl initially, drying somewhat flatter but still not flat
      The Grandmother Stover's - Never curled, Stukflat, Stayingflat!
      Please do your own experimenting and please share your comments! I'd love to hear about what has worked (and not worked) for you!
      I know what I'll be using for the wood floors on the Alki Point! Good old Grandmother Stover's!
    • By Call Me Crazy
      So, half-scale furniture.  What's out there for purchase is getting limited as manufacturers close down or discontinue production.  What I see for sale is overly ornate, not the style I want, or too niche.  I could be wrong, but I think most of us are building houses, not shops or dentist offices.
      Some of you have the skill to make your own furniture.  I built a passable corner cabinet, but my crafting skills aren't that great and I have very limited tools.
      That brings me to kits.  I've made a few by Cassidy Creations that have come out great, but too often those kits have missing pieces, pieces the wrong size, and confusing/wrong instructions.
      There are some great sellers on Etsy making laser-cut kits.  Those I've made successfully were from RedCottageMiniatures, SDKMiniatures, MelissasMiniWereld, and HalfScaleMiniatures.
      I'm curious to know whose kits have others had success with.  Do you have a favorite designer/seller?  What do you like best about the kits?
    • By suse53
      does anyone know where i can get the building instructions for greenleaf No. 9010?  its the 56 piece furniture set i believe. the schematic sheet says dollhouse furniture kit, thats it.  hope someone can tell me where i can find the instruction sheet.
      thank you
      sue
    • By WBrownIV
      Here is the label. It's made by a company called "Molotow" The trick with it is to apply it almost to where it runs. Then don't touch it for a few days.
    • By WBrownIV
      This is the Chrome paint I used. It truly works!
