Msdemeanr Posted October 21, 2018 Share Posted October 21, 2018 Hi there - I’m sorry if this is the wrong place to post this. I searched the topic in the forums and I saw the awesome end results but not the steps to do it. I’d like to do a linoleum type of floor in the bathroom and kitchen. I’m still really new and still learning. Any recommended patterns or what to put on top to give it the texture? I tried scrapbook paper and Modpodge but it got too soggy and curled, it didn’t get thick like I wanted it to. Am I missing some vital step? (Probably ;)) I’m looking for something you would find in a 60s or 70s type house, but not over the top. Like the type of linoleum you find at mom’s/grandma’s house. Quote Link to comment Share on other sites More sharing options...
Sable Posted October 21, 2018 Share Posted October 21, 2018 Go to Home Depot or Lowe’s and purchase one square of linoleum floor. I use a guillotine style paper cutter to cut small pieces into squares. Here is an example by Robin Carey: http://robincarey.blogspot.com/?m=0 Quote Link to comment Share on other sites More sharing options...
Sable Posted October 21, 2018 Share Posted October 21, 2018 Another thing I did was to apply scrapbook paper to a thin primed (on both sides) board. Then I added at least three coats of water based gloss polyurethane. I used a satin gloss finish in this room but you might want to go with a higher gloss finish: http://www.greenleafdollhouses.com/forum/?app=gallery&module=gallery&controller=view&id=134995 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 21, 2018 Share Posted October 21, 2018 My linoleum exposure predates yours by fifteen or twenty years. For most of my "linoleum" floors I choose the base color I want and paint the floor that color and let it dry. I then dip an old splayed-out toothbrush lightly into a contrasting color and hold it over the floor and rub it with my thumb to get the color to splatter in tiny droplets and splotches and let it dry. I repeat the toothbrush treatment with a couple of other colors and wind up with what looks like the linoleum floors I grew up with. Quote Link to comment Share on other sites More sharing options...
Msdemeanr Posted October 21, 2018 Author Share Posted October 21, 2018 Thanks! I think I’ll try both on a little test square and see what turns out. Now to brave the stores on a Sunday... Quote Link to comment Share on other sites More sharing options...
Intrinsicat Posted October 26, 2018 Share Posted October 26, 2018 I've done both - the flooring samples at Home Depot, I definitely didn't have the right cutter to get through those thick boards! I ended up using the scrapbook paper with modge podge. But I didn't apply the modge podge until the paper was already glued down using this awesome glue called Gane Yes All-Purpose Stik Flat Glue. I saw it on a wallpaper tutorial on Youtube and ordered it on Amazon. It's AWESOME and none of my wallpaper or flooring has warped since, even when I heavily apply the modge podge to it. Quote Link to comment Share on other sites More sharing options...
Sable Posted October 26, 2018 Share Posted October 26, 2018 Sounds like you were using laminate flooring and not the square linoleum tiles. Quote Link to comment Share on other sites More sharing options...
