Thimble Hall Posted April 13, 2018 Share Posted April 13, 2018 I did think about that but these are extremely tiny hinges, smaller than anything I have used before and I am a bit nervous that the super glue will get into the hinge part but I will try it I think,. thank you Carrie, you have given me the courage I needed. Rebecca I would still like to know what you did with yours.. Quote Link to comment Share on other sites More sharing options...
Sable Posted April 13, 2018 Share Posted April 13, 2018 2 hours ago, Thimble Hall said: I did think about that but these are extremely tiny hinges, smaller than anything I have used before and I am a bit nervous that the super glue will get into the hinge part but I will try it I think,. thank you Carrie, you have given me the courage I needed. Rebecca I would still like to know what you did with yours.. I just used tiny hinges on my bar. I didn’t predrill the holes. First I put a tiny drop of crazy glue to set the hinge, then I pushed the pins in place with a hemostat and lightly hammered them. Quote Link to comment Share on other sites More sharing options...
Thimble Hall Posted April 13, 2018 Share Posted April 13, 2018 Sable thank you for the answer. I have already drilled the holes but it is still good to know for another time. It is not wood and is hard so I am not sure if I could hammer them as my dexterity is sometimes a problem and they don't have a point on them. Actually it was funny when I was placing them as periodically my rotten arm would twitch and the tiny pin went flying..impossible to find too so I am now missing a couple.My hemostats were too thick to pick them up so I was using needle tweezers. On the positive side I am still enjoying the project, I have now stripped the wallpaper off twice . it just wasn't right and am waiting for a parcel to come from the UK before I do it again. I will wait till that comes before I glue them though. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted April 13, 2018 Share Posted April 13, 2018 Jeannine, slip a knee-high stocking over the suction hose end and fix it with a rubber band; I used to find all my eeny little brads that way. 1 Quote Link to comment Share on other sites More sharing options...
Thimble Hall Posted April 13, 2018 Share Posted April 13, 2018 Holly great idea that is worth knowing about but these could be anywhere they really flew and they are only about 1/8th of an inch long. I will try it though around the area.If the cleaner picks them up they will be among a great heap of dog hair. so that will be fun. I was doing it on the coffee table in the living room which of course has low pile shag. I did try a magnet on them but they didn't react of course. I actually do have some extremely tiny sewing pins which fit the hole perfectly and the head is bang on for size but are a little too long however I could snip them off. They are not the same color but I can adjust that. Lots of fun Quote Link to comment Share on other sites More sharing options...
Shareb Posted April 15, 2018 Author Share Posted April 15, 2018 On 13/04/2018 9:51:52, Thimble Hall said: Rebecca, can you help me please? I am just at the point of fitting the hinges. The door is held securely in place with masking tape right now . I have drilled tiny holes the same size as the pins and placed the hinges over the holes, then dropped the pins in. It has all lined up good but I have to secure them,the pins are a tiny bit loose .Did you glue the hinge and pins to the door etc. I am really stuck now. I'm so sorry I didn't see this before now Jeannine! Did you get it working? The first time I just held the hinges in place with tape, used a sharp pointy tool to indent the wood (can't remember what they're called) and then hammered the pins in. When I had to take the door off in order to wallpaper, the holes were slightly loose when I put them back in, so as Carrie suggested, I used a drop of superglue under the hinges and that seems to be working well. Message me or quote me and that will send me a notification. Quote Link to comment Share on other sites More sharing options...
