Orchid Bay Window > French Doors
Howdy everyone,
I'm currently working--slowly but surely--on my first house (surprise!) The Orchid. I was wondering, has anyone tried to modify the side sheet containing the bay window to suit French doors? I've swapped the side sheets, in favor of more wall space in the "parlor" (the larger room to the left), so now the bay window would look in on the small kitchen under the stairs. I'd prefer to "open up" the space by allowing more light in; also, I must admit I don't love the idea of working hard to build that bay window if it isn't going to be a focal feature.
Relatively long story somewhat shorter, have any of your found that it was possible to convert the bay window into a space fit for French doors? If so, how?
Any and all guidance is deeply appreciated! Hope everyone is having a lovely holiday!
Yep, I did it. Just cut a bigger hole around the bay window hole, that's the size of the Houseworks french door.
dollhouse5.jpg.83f245966e05a5a82d45aca93
free-orchid8.jpg.918586d0c5a8c2729705049
I did it so I could use the Houseworks conservatory as an addition, that's what that other piece is in the first photo. Sorry I don't have a better picture, I gave this house away a while ago.
But if you're switching the walls, does that mean your stairs will run up the wall where you want to put the french door? In that case it seems like you won't have room for the double door. You might be able to fit a single french door underneath the tallest part of the staircase. In that case don't punch out the bay window pieces -- use wood filler to fill in the grooves where they would have been punched out -- and then you can cut a new door hole. The plywood is fairly easy to cut by hand with a utility knife - if you're using a Houseworks door you can do a rough job cutting the hole, because the trim will cover up the edges.
Hope that helps!
Hope that helps!
WOW I love this idea and will probably steal it since I have an Orchard waiting in the wings to make . My only issue is i'll probably want to keep it and where will I have the room?  Miniatures my love / hate obsession .
Hi Emily,
Thanks for this! I'm glad that you were able to achieve this; my idea was, coincidentally enough, also to leave room for a future conservatory. You made a very good point, that stairs may very well interfere with the double doors. I may try the single french door instead. This is a wonderful suggestion! Unfortunately, I've already punched out the bay window pieces (I'd planned to paint them before assembly, until I discovered this might not be the route I wanted to take). So, it seems I'll have to find another way to make this work! Perhaps I'll even return that panel to its original side and have French doors in the parlor; it may be worth sacrificing the wall space.
In any case, I'm very grateful for your help!
Do you still have the pieces you punched out? You can glue them back in.
Here's how it looks with the conservatory. The upstairs window pieces also need to be left in or else the top of the conservatory would bump into the window.
(This was the first house I built and I cringe when I see it now! Those colors! I bought quarts of paint at Lowe's because I didn't know any better, and then I felt like I had to use them even though the colors weren't what I'd envisioned. I learned a lot from this build...)
I do! Perhaps I can glue them back in. Also, the house looks great with the conservatory! I'll admit, the color scheme could be a bit overwhelming; but nonetheless I very much like the house. Do I see that you have a dining area set up in the conservatory? Or, do my eyes deceive?
Hi Eli and welcome.  In my Orchid I just put a new houseworks window in instead of the bay window.  I had to buy a bigger window and make it smaller to fit the hole, it was my first house also.
  • 3 weeks later...
This is also a good idea. Thank you!
  • Similar Content
    • By Boden
      Hi Everyone,
      I need a little help with the Orchid's double hung windows and staining/paint the surrounding walls. Sorry if a simliar question has been asked before, but I could not find an previous blog post.
      For part B of assembly, the directions say that the "portion of the wood surrounding the window opening, both interior and exterior, should be finsihed as the sashes have been (i.e. paint or stain) before gluing the sashes in place."
      (I stained my window sashes a dark brown, but I plan to paint the exterior a light blue. For the interior I want to do stucco.)
      So my question: how do I measure how much I should stain around the window on the house's walls? When I look at pictures of finished Orchids online it's not obvious to me that everyone has followed this direction. Is it really that important?
      -Sarah
    • By third_hand
      Hi everyone! I've had a long quiet period on here, but I've been steadily working away and going to shows/shops (I was at Good Sam in San Jose and was fortunate to visit Dollhouses, Trains, and More in Novato, CA for their closing sale). I will, finally, post a batch of haul and progress photos in the first week of November, when I get settled back into my home in Eugene. I really am terrible with a camera and it bugs everyone I know! In the meantime, I have a question:
      Has anyone ever tried adding siding after their build's exterior was complete? Still being a novice, when I finished my first build (the Orchid; the interior is still a work-in-progress) I stepped back and thought 'I think I should have done siding.' Especially with the shingles on, the level of detail on the exterior just varies too much; it's been irritating me for a couple of months now. I'm a bit of a stickler it seems (though I didn't know it at the time)! My window/door casings, dormers, gingerbread, and my custom porch/railings are all already in place. I realize it may be very difficult, but the question is: is it even possible? If so, do you have any tips on how to do this?
      Any and all possible mini wisdom is welcome!
      P.S. I have the opportunity to snag a very affordable Laurel kit secondhand so I'm trying to decide where I should just start the next building with siding and call it 'lesson learned' or go back and add to the Orchid (and stash the Laurel until after the New Year, space is a very important consideration here). P.S. P.S.: I'm not a Cher fan, but I took a page out of Elizabeth's book (Studio E miniatures) since I'm always charmed by her ability to make musical jokes in her posts/titles!
    • By PapaJKK
      All the window parts. After sanding, filling, sanding, and more sanding, painting, sanding, painting and sealing, the windows are ready for assembly. I chose to glue the top frame in and only the bottom frame opens. This helped make a rigid window frame that can be handled without falling apart. Notice the gluing jig I made for assembly.
    • By PapaJKK
      15 windows, 11 pieces per window, 161 total pieces. Nice to have that bit finished.
    • By hmayonayz
      I finally got it! I'm building my first house, the Orchid.  I literally sat and stressed for hours yesterday about the stairs, which were horrible and splintery and way too big really for the housel. So I found angieaug's video on youtube and the lightbulb went on. I cobbled together a set this morning that fits like I want and she made it easy as pie. Eating pie that is, lol. So thanks to her! They are drying but I need to figure out wallpaper and stuff before I put them in permanently.
