Painting
debbru
27 minutes ago, debbru said:
When painting the outside can someone tell me how they hide the notches
If you're not going to use siding or plaster the walls with spackle (or joint compound, or wall mud), you can at least use spackle to fill the slot spaces after you have sanded the tabs flat, and when the filler is dry, sand that smooth as well; then you're ready to prime and paint.
To hide horizontal notches (floor/ceiling) I've seen a piece of stripwood run across the wall. When painted, it blends into the wall and looks like an architectural component.
54 minutes ago, debbru said:
Thank you for your reply, I was talking about the outside of the house
Holly and I are both talking about the outside of the house. The methods we describe are for covering the little areas where the tabs from the ceiling/floor pieces fit into the slots in the walls. Where walls are notched at corners, Holly's Spackle/joint compound/wallboard mud system also works. Some people also put corner molding on the corners to cover those irregularities.
If this isn't what you mean, can you please explain or show a photo?
Covering with spackle as a plaster or stucco treatment:
with corner molding:
and with siding:
  • 1 month later...
I really like the elmers wood filler from Home Depot.
