Geemom Posted January 7, 2016 Share Posted January 7, 2016 The glue has dried on the foundation and there are a few corners that did not seat perfectly. My floor was warped to begin with, so I did have to weigh it down to assemble and was unable to check the fit completely before gluing. Before trying to loosen glue and correct the corners, I measured around the foundation to see exactly what was off and what was just due to part variance. It measures mostly at 2 inches, with a few areas smaller by 1/16 to 1/32 of an inch. Does that make sense? I know it doesn't seem like much, but I know by the time I build three stories the difference is going to have a larger impact. My question is, how close does the foundation have to be before it totally throws the rest of the house off? I have built things before, but this is my first dollhouse kit. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 7, 2016 Share Posted January 7, 2016 When you did your dry fit, did you shave or sand all the tabs & slots to get a more precise fit? Quote Link to comment Share on other sites More sharing options...
Geemom Posted January 7, 2016 Author Share Posted January 7, 2016 Yes I did. They all fit together individually, as a whole there was an issue because one of the floor pieces had a slight warp. With tape and some heavy books, it would fit. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 7, 2016 Share Posted January 7, 2016 If it's off a whole lot more than can be fixed with a bit of spackle I'd probably take it apart and reglue it so it all fits (I have done this...) Quote Link to comment Share on other sites More sharing options...
Geemom Posted January 7, 2016 Author Share Posted January 7, 2016 Thanks. It can definitely be fixed with spackle. Quote Link to comment Share on other sites More sharing options...
Sapphire-Star Posted January 8, 2016 Share Posted January 8, 2016 My floor was warped and I had to pile books on top. Hope everything works out with the Spackle. 1 Quote Link to comment Share on other sites More sharing options...
