I was able to get my Orchid unpacked yesterday at I started priming to the wood sheets.  I was excited that the kit came with shingles, but that was until I saw them.  These shingles are literally paper thin and when I took them out of the box they started splitting and crumbling.  I'm beginning to think I will need to buy "aftermarket" shingles to get higher quality ones.  Has anyone else experienced these paper thin shingles?  Am I right in thinking that I will have to buy other shingles?
They all are thin so it will match the scale properly.
If the kit is an older one, they could just be dry.  Perhaps some wood conditioner would add moisture back to them.
They always pack more in those bags than the number stated to account for breakage anyway. You will need some smaller pieces to fit in the angles and edges so don't throw them all away quite yet.
I love those uber thin wood shingles!  If you stain them with an oil-based stain it should help recondition the wood, and you might want to stain them before applying them to the roof.  I didn't use the shingles with my wood version of the kit, because I had seen a RL lozenge-shape shingle pattern I wanted to use instead, and sandpaper replicated it nicely.  I have used those shingles on subsequent builds.
I was just wondering the same thing. Same house, too. I used a thicker, sturdier shingle for another house, but that house was bigger and beefier anyway, so they seemed to suit it. I have some octo shingles that are sort of in between the two, and was thinking of using them for the Orchid. I'm going to try staining a handful of the thin shingles first, though.
I have a shingle update if Vickie is interested. I used the kit shingles, and it's turning out fine. I trimmed and sanded the edges of EVERY SINGLE ONE which was a huge chore, but they were unusable out of the box. After all of that, stained them, then gluing them on one by one, and it looks much better than I expected. The super thin shingles are very easy to trim with scissors, so no other cutting tools are needed. I set them with maybe a 1/16"-1/8" overhang. Any more than that and they get too fragile on the edge. I also used more glue along each edge shingle, to make it more secure, all of the rest are glued on with two dots of glue. There's a pic of the start of the roof in my gallery. And yes, keep any broken shingles and trimmings from the edges, I used them to fill in when I just needed a sliver of wood, rather than cutting up a whole shingle.
I just revisited your album. How did you get the walls so smooth? Did you apply drywall mud to them?
Sable, it was a lot of sanding! I sanded raw wood with 180 grit, then primed everything with shellac. Then rolled on a few coats of gesso, using a 6" foam roller, sanding lightly in between. The foam roller gives a tiny bit of a "slapbrush" type texture, just like real drywall. The goal wasn't really a textured wall, but more to just obliterate the wood grain. I also used either flat or eggshell finish paint (2 coats), which helps to cover a lot of sins.  Really thin drywall mud would probably work, too.
I really wish the kit makers would use the smoother side of the wood for the interior. Not everyone wants to use wallpaper, and most people cover the exterior with siding, or some other applied finish anyway. Or better yet, make both sides smooth!
I used the thin shingles on my sugarplum. They are super easy to cut to size. I just wish I would have squared them off. Otherwise I think they are good
  • Similar Content
    • By Boden
      Hi Everyone,
      I need a little help with the Orchid's double hung windows and staining/paint the surrounding walls. Sorry if a simliar question has been asked before, but I could not find an previous blog post.
      For part B of assembly, the directions say that the "portion of the wood surrounding the window opening, both interior and exterior, should be finsihed as the sashes have been (i.e. paint or stain) before gluing the sashes in place."
      (I stained my window sashes a dark brown, but I plan to paint the exterior a light blue. For the interior I want to do stucco.)
      So my question: how do I measure how much I should stain around the window on the house's walls? When I look at pictures of finished Orchids online it's not obvious to me that everyone has followed this direction. Is it really that important?
      -Sarah
    • By third_hand
      Hi everyone! I've had a long quiet period on here, but I've been steadily working away and going to shows/shops (I was at Good Sam in San Jose and was fortunate to visit Dollhouses, Trains, and More in Novato, CA for their closing sale). I will, finally, post a batch of haul and progress photos in the first week of November, when I get settled back into my home in Eugene. I really am terrible with a camera and it bugs everyone I know! In the meantime, I have a question:
      Has anyone ever tried adding siding after their build's exterior was complete? Still being a novice, when I finished my first build (the Orchid; the interior is still a work-in-progress) I stepped back and thought 'I think I should have done siding.' Especially with the shingles on, the level of detail on the exterior just varies too much; it's been irritating me for a couple of months now. I'm a bit of a stickler it seems (though I didn't know it at the time)! My window/door casings, dormers, gingerbread, and my custom porch/railings are all already in place. I realize it may be very difficult, but the question is: is it even possible? If so, do you have any tips on how to do this?
      Any and all possible mini wisdom is welcome!
      P.S. I have the opportunity to snag a very affordable Laurel kit secondhand so I'm trying to decide where I should just start the next building with siding and call it 'lesson learned' or go back and add to the Orchid (and stash the Laurel until after the New Year, space is a very important consideration here). P.S. P.S.: I'm not a Cher fan, but I took a page out of Elizabeth's book (Studio E miniatures) since I'm always charmed by her ability to make musical jokes in her posts/titles!
    • By Fkendall
      I bought my Thornhill house about 18 years ago! Began it then and only found time to get back to it now I'm retired. I had attached some of the shingles and they have darkened and the ones I'm applying now are a completely different colour. Will the new ones age darker to match the others? Or must I paint them all? Any ideas grateful received!
    • By hmayonayz
      I finally got it! I'm building my first house, the Orchid.  I literally sat and stressed for hours yesterday about the stairs, which were horrible and splintery and way too big really for the housel. So I found angieaug's video on youtube and the lightbulb went on. I cobbled together a set this morning that fits like I want and she made it easy as pie. Eating pie that is, lol. So thanks to her! They are drying but I need to figure out wallpaper and stuff before I put them in permanently.
    • By gimpnelly
      Hi there! I just purchased an Orchid kit that I’m very excited to build and wanted to join this community to chat about it! I have one unfinished dollhouse that’s just too big for my current home (it’s 32” wide and I needed something smaller), so I decided to start over again. By day, I’m in marketing and I live with my fiancé and our two cats in Madison. I also like to read, write, play video games, watch TV, and see live music. Nice to meet you all!
