Shareb Posted January 9, 2015 Author Share Posted January 9, 2015 I have seen as I've been reading through the forum, talk of changing the ladder in the Pierce for a spiral staircase or similar. I'm really keen on knowing more. Do you buy a spiral staircase complete and if so, where from? Or do you build the spiral staircase yourself somehow? Quote Link to comment Share on other sites More sharing options...
Selkie Posted January 9, 2015 Share Posted January 9, 2015 You can buy kits, purchase ready made, or build custom. Probably a higher percentage custom build. There are some bridal favor fans at some craft stores that make great treads. That are carved sandalwood. I'll see if I can scrounge up a picture. Try this. http://www.bellestyles.com/images/6203.jpg 1 Quote Link to comment Share on other sites More sharing options...
Shareb Posted January 9, 2015 Author Share Posted January 9, 2015 What a wonderful idea! I guess you would just need a centre pole and then you would add the steps in equal distances as you go up and around. Quote Link to comment Share on other sites More sharing options...
Selkie Posted January 9, 2015 Share Posted January 9, 2015 You can use beads to hold the separation of the steps. Railings can be things like rope, thread, yarn, ribbon, wire, straws, leather, chains, thin wood soaked and bent (the hardest to do). Posts can be decorative toothpicks, small dowels, sticks/twigs, more parts of the fan, etc, etc. 2 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 9, 2015 Share Posted January 9, 2015 Our own member Don makes spiral staircase kits and Here is nice tutorial for spiral stairs: http://www.smallstuff-digest.com/spiral_staircase.htm 2 Quote Link to comment Share on other sites More sharing options...
clairevc Posted January 26, 2015 Share Posted January 26, 2015 The Beacon Hill staircases are a nightmare!!! Not to mention all the splinters I've gotten. Finally got the 1st floor staircase done, sanded and painted. I would like to stencil them. Any suggestions??? Quote Link to comment Share on other sites More sharing options...
Selkie Posted January 26, 2015 Share Posted January 26, 2015 They make clear water transfer decals if you don't want to paint your own. You can use small decorative wood designs glued on as embellishments and painted or stained as desired. Old jewelry bits and bobs can be added as embellishments as well, either painted or left the ordinal color. You can cut your own stencils or purchase them and paint them or add some varnish/poly and use metal or embossing powders to create old world gold, copper, brass, or silver decorations and then top coat them. 1 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 30, 2015 Share Posted January 30, 2015 You can also decoupage bits and bobs from wrapping papers, greeting cards, etc. 1 Quote Link to comment Share on other sites More sharing options...
KariW Posted January 31, 2015 Share Posted January 31, 2015 Don't use mod podge on the floors. It dries tacky. I read that there is another type that doesn't dry sticky, but I didn't look for it yet. I used krylon clear coat spray to fix the tackiness issue. Granted, that was after I broke some furniture, because I had to pry it off the floor. 1 Quote Link to comment Share on other sites More sharing options...
Shareb Posted January 31, 2015 Author Share Posted January 31, 2015 Thanks Kari!! Very good to know that!! Quote Link to comment Share on other sites More sharing options...
Mimajo Posted February 14, 2015 Share Posted February 14, 2015 The Beacon Hill staircases are a nightmare!!! Not to mention all the splinters I've gotten. Finally got the 1st floor staircase done, sanded and painted. I would like to stencil them. Any suggestions??? The only thing I have used tweezers for....splinters! 2 Quote Link to comment Share on other sites More sharing options...
