Buffy Posted October 25, 2013 Share Posted October 25, 2013 Just starting my first build and am having problems with the chimney. I am building the Buttercup and can't make heads or tails of the instructions!!! Anyone have a problem with this? It's probably just me but any advice is welcome. The instructions read "position chimney top to opening" and when I do this it falls straight through as the top is smaller than the chimney. I clearly am missing something and know I am going to be so embarrassed if and when I figure this out! Thanks Quote Link to comment Share on other sites More sharing options...
Dalesq Posted October 25, 2013 Share Posted October 25, 2013 Take a deep breath. You're not missing anything, the instructions aren't that clear. As I recall, the chimney top fits inside the chimney sides and the stack fits inside the opening in the top. I built the stack, then glued it into the top. Built the chimney sides, and then glued the top to the chimney itself. You'll need something to hold the top in place. I think I used some cardstock to create an interior ledge for the top to rest on while the glue set. There are a second set of instructions available for download with very nice diagrams for the Buttercup. You can find them on this site under downloads. Hope this helps. Quote Link to comment Share on other sites More sharing options...
buckeyepie Posted October 26, 2013 Share Posted October 26, 2013 I couldn't understand the institutions either so I nixed the chimney all together, well at least so far, I dry fit everything them put it back in box, have another project wanna do first Quote Link to comment Share on other sites More sharing options...
minime Posted October 26, 2013 Share Posted October 26, 2013 There are at least two different sets of instructions for the Buttercup. Here's a link to the newest version http://www.greenleafdollhouses.com/forum/index.php?app=downloads&module=display§ion=download&do=confirm_download&id=52 . It may be different and more helpful than the one you have. 1 Quote Link to comment Share on other sites More sharing options...
Buffy Posted October 27, 2013 Author Share Posted October 27, 2013 Thank you all for the help. Quote Link to comment Share on other sites More sharing options...
