Zoey Posted June 27, 2013 Share Posted June 27, 2013 I have a chance to buy lights and spare bulbs at a good price. The bulbs are attached to a wire. Does this mean that I could use these and make a light fixture or are the bulbs just used to replace another bulb from an existing fixture? Quote Link to comment Share on other sites More sharing options...
Jeffrey Posted June 27, 2013 Share Posted June 27, 2013 you could use them to make your own custom light fixture but they may or may not be replaceable if the bulb burns out. It depends if the wire is attached to a screw base socket with a bulb screwed into that or if its actually the bulb itself attached to the wire. either way you can make your own light. Quote Link to comment Share on other sites More sharing options...
