acherrera3 Posted August 3, 2012 Share Posted August 3, 2012 Would anyone please let me know the dimensions of the second floor bedroom? Im planning ahead. Quote Link to comment Share on other sites More sharing options...
fov Posted August 3, 2012 Share Posted August 3, 2012 Ceilings are 4" high and the rooms are 6" deep. If I'm measuring correctly, the room with the windows is approx. 6.75" wide and the one without the windows is 6.5" wide. The chimney juts into the room about 5/8" and is 3" wide. There's about 1.5" inches on each side of the chimney. Hope that helps! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 3, 2012 Share Posted August 3, 2012 I had room in all the bedrooms for a double bed, a bedside table and chair or chest. Quote Link to comment Share on other sites More sharing options...
acherrera3 Posted August 24, 2012 Author Share Posted August 24, 2012 Another question for you. Would someone please let me know the size of the second floor hall windows, and the attic windows (height & width)? Thanks so much for your help. Quote Link to comment Share on other sites More sharing options...
fov Posted August 25, 2012 Share Posted August 25, 2012 Are you asking for the size of the openings, or the size after trim is installed? If you're using a "newer" kit (manufactured within the last ~10 years) then all of the 1st and 2nd floor window openings should be the size of Houseworks windows. You can find the dimensions of those here. (If you are using the older kit, then I think the openings are a tad smaller.) I didn't use the trim kit so I can't speak to the dimensions of those windows with the regular Fairfield trim, but it should be roughly the same as the Houseworks windows. The 5-sided windows on the third floor are about 1 1/2" wide by 2" tall (at the peak), with trim. The trim's 1/4", so I guess that would make the openings about 1" by 1 1/2". Is that what you needed to know? Quote Link to comment Share on other sites More sharing options...
acherrera3 Posted August 26, 2012 Author Share Posted August 26, 2012 Yes, thank you. I'm trying to decide what windows I would like to use. This is worse than building a real house!! ;) Quote Link to comment Share on other sites More sharing options...
fov Posted August 26, 2012 Share Posted August 26, 2012 Definitely double check the dimensions before you buy, but I think any of the Houseworks windows will work. For the attic windows, years ago there were pictures in Nutshell News of a really pretty bash that had "half height" Victorian windows to match the ones downstairs. I don't think these are commercially available for half scale, maybe the person made them from full windows. There's a picture of it here. You could do this with any of the Houseworks styles. I did something similar with 1:12 windows... it was a little easier than it would be with the 1:24 windows because the window sill came detached. But anyway, there are lots of bashing possibilities! (I almost did something like this for my Fairfield but didn't have the confidence, and ended up not doing it... now I wish I had!) Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 26, 2012 Share Posted August 26, 2012 Doesn't HBS still sell the 1:24 Houseworks component windows and doors for the Fairfield? Quote Link to comment Share on other sites More sharing options...
sparklepuppies Posted August 26, 2012 Share Posted August 26, 2012 Doesn't HBS still sell the 1:24 Houseworks component windows and doors for the Fairfield? Yep. http://www.miniatures.com/12-Scale-Fairfield-Upgrade-Component-Set-P18064.aspx But wait until a sale to buy them. They send out emails to their mailing list when they have one. Quote Link to comment Share on other sites More sharing options...
fov Posted September 2, 2012 Share Posted September 2, 2012 There's a lot on eBay right now that could be an even better deal if it doesn't get a ton of bids: http://www.ebay.com/itm/Dollhouse-1-24-lot-12-Victorian-Windows-H5042-1-door-H6013-plus-2-cupolas-H2407-/320975062008?pt=LH_DefaultDomain_0&hash=item4abb9ac3f8 Includes 12 Victorian windows, one Victorian door, and two cupolas (which you could choose to use on the Fairfield, or not). It doesn't include the interior doors, but even if you bought those separately it'd be cheaper than the Miniatures.com bundle. Starting bid is $19.99. Quote Link to comment Share on other sites More sharing options...
