kellyannmo Posted July 15, 2012 Share Posted July 15, 2012 Hello everyone.... I am working on my Blackwood Hall again (a Duracraft Queen Anne) I am at the crown molding stage in a few rooms and I am dragging my feet. Normally I like this stage, but the Duracraft houses have that funny little "bump out" from the corner posts used in assembly. I know Brae padded her walls to help eliminate this problems... I am well past that stage as most walls are wallpapered already.... so I am looking for solutions to this problem... and thoughts or pictures of how you worked around this would be greatly appreciated. The image shows one of the corners..... to the left of the clock Thanks ya'll Quote Link to comment Share on other sites More sharing options...
fov Posted July 15, 2012 Share Posted July 15, 2012 Two thoughts - either butt the crown molding up against the corner post, which would actually make it much easier, since you wouldn't have to cut funny angles, but it kind of depends on how big your crown molding is, it wouldn't work if the profile of the molding is significantly bigger than the corner post. Or do the crown molding as your normally would but carve out a space at the back of the molding pieces so they will nestle on top of the corner post. (I'm not exactly sure how to describe that, does it make sense?) Quote Link to comment Share on other sites More sharing options...
otterine Posted July 15, 2012 Share Posted July 15, 2012 I used Mike's idea for corner blocks in the kitchen where my connectors were still visible. I cut out a notch in the block and then cut the crown molding to butt against the blocks. http://www.greenleafdollhouses.com/forum/index.php?app=gallery&image=77100 More detailed pics on my blog: http://www.otterine.com/blog/blog1.php/kitchen-crown-molding Quote Link to comment Share on other sites More sharing options...
KathieB Posted July 15, 2012 Share Posted July 15, 2012 The block that Brae used with a tiny finial hanging down would fit with the style of your house. Quote Link to comment Share on other sites More sharing options...
DocGreen Posted July 15, 2012 Share Posted July 15, 2012 There are some photos in my FH-505 farmhouse gallery that show my solution to the problem. Hope it helps. If you need more info just let me know. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted July 15, 2012 Share Posted July 15, 2012 I used crown molding to help place the floors of the rooms above,and fit them between the corner posts. I didn't paper over those corners, through; I painted them to match the rest of the trim color inside. Quote Link to comment Share on other sites More sharing options...
kellyannmo Posted July 15, 2012 Author Share Posted July 15, 2012 Hello ya'll... thanks everyone for your input... I knew you would have some great ideas.... I had some corner blocks... and went with Brae's (Mike's) idea although I think I am going to keep on with Kathie's thought and add a finial hanging down.... thanks ya'll Quote Link to comment Share on other sites More sharing options...
otterine Posted July 16, 2012 Share Posted July 16, 2012 Glad to help! I think the extra bit of fancying up will be perfect! Quote Link to comment Share on other sites More sharing options...
KoalaSam Posted July 16, 2012 Share Posted July 16, 2012 Glad this came up as I have been wondering how to finish my Dura Craft house. Thanks, I am going to use this information too. Quote Link to comment Share on other sites More sharing options...
doc Posted September 7, 2012 Share Posted September 7, 2012 Another solution is to put a piece of stripwood between the connectors to build out the wall to the thickness of the connector, then crown over the stripwood and the connector. The stripwood should be a little taller than the crown. I have used this solution with a circa 1975 Batrie New Orleans, then used a light crown molding that got extra thickness from the stripwood for a nice Victorian look. I do like the notch-out-the-back idea, particularly if the crown is already nice and heavy although it might get complicated in a bay section. Quote Link to comment Share on other sites More sharing options...
