Minsanity Posted May 12, 2012 Share Posted May 12, 2012 I'm finally ready to glue the interior door trim then get to work with the baseboards and molding. I wanted to check though before i glued - it seems like the wood that goes over the doors is thinner than the pieces to the side of the doors. Anyone who has a Beacon Hill remember this? I dont believe there are any other sheets that have pieces that would work so i dont think i'm wrong here, but wanted to check. As aways, THANK YOU! Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted May 12, 2012 Share Posted May 12, 2012 If I remember correctly, the doors are thinner wood just like the trim pieces are. can't wait to see more pictures! Quote Link to comment Share on other sites More sharing options...
-defunct account- Posted May 12, 2012 Share Posted May 12, 2012 Are the doors and trim you plan on using the included ones from the kit sheets or some you bought separately? If there is a thickness issue it should be easy enough to fix. Do you have a pic? Quote Link to comment Share on other sites More sharing options...
Minsanity Posted May 13, 2012 Author Share Posted May 13, 2012 Thanks to you both! I have not made much progress but will post pictures. It isnt really a thickness issue as much as the top trim is not as wide as the bottom. I'll post pictures. Quote Link to comment Share on other sites More sharing options...
-defunct account- Posted May 13, 2012 Share Posted May 13, 2012 Okie I see what you're saying. I've either filled with spackle or replaced the top with scrap Quote Link to comment Share on other sites More sharing options...
