anpak Posted August 18, 2011 Share Posted August 18, 2011 Ok, we have the main parts of the Orchid glued together - BUT both floors sag in the middle. The top floor sags even with the bottom partition in, and the bottom floor also sags. We have not even put in the wood floors/tiling we plan to add. Any suggestions? Have other people had this problem? Quote Link to comment Share on other sites More sharing options...
dooder85 Posted August 18, 2011 Share Posted August 18, 2011 thicker pieces of wood/doweling placed under the bottom floor should prop up the 2nd floor, floor joists if you will Quote Link to comment Share on other sites More sharing options...
amyole Posted August 19, 2011 Share Posted August 19, 2011 I'm not sure if I can explain this clearly, but I'll try. I have glued pieces of wood under the flooring that are the same thickness of the base support (space under floor) and then I glue the whole thing to a larger support board that will be the "yard" around the house. This helps to stabilize the whole house and it helps with the floors. There are lots of good examples of what this looks like in the gallery. It will also help keep the front steps from falling off (my first Orchid -RIP - I hot-glued it and it was not on any board; when my daughter gave it away, the front steps had already started to separate from the house - from this forum I have learned soooo much). Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 19, 2011 Share Posted August 19, 2011 Abby, did the floors not sag in dry fit? If you used hot glue my suggestion would be to take the house back apart and deal with the sags by misting the saggy parts and then weight them down with flat, heavy weights until dry and flat. Otherwise, as has been suggested, go with straight pieces of stipwood below and think of ceiling beams. Quote Link to comment Share on other sites More sharing options...
anpak Posted August 21, 2011 Author Share Posted August 21, 2011 Thanks for the suggestions! I did not use hot glue so I can't take it apart again. However, I hadn't thought about putting the whole house onto a board to stabilize it - I do think that is a great idea. I can then put the floor joist underneath the first floor to keep it from sagging more. Too bad about your first Orchid, Amy! Quote Link to comment Share on other sites More sharing options...
wildflower47 Posted February 24, 2013 Share Posted February 24, 2013 I am putting the divider in the center making an entry way in frount of the door. And supports under the first floor. That solved the saging floor prob for me. I don't know how to add pics or I would show what I did. Quote Link to comment Share on other sites More sharing options...
