Basic Painting Tips
StephanieEloise
Okay, some more questions - could anyone list basic steps when it comes to painting? I've heard lots of differing opinions. Like, what do prime with? I have a can of flat latex lying around and thought I'd use that up if that would work. What brand is good for the exterior? I'm painting my door and steps and some accents black, will painting them glossy make a difference? Should I seal everything first?
Thanks in advance.
I'm not positive about the differences in types of paint as I've only ever used acrylic paints mixed with satin varnish as final coats on houses and as a primer I used regular acrylic white (I have a lot of this paint from other crafts). But I can say don't prime anything you're wanting to stain and also don't seal anyplace you want stain as the stain won't adhere. Seems like a simple concept but can take some advance planning LOL. Also, remember to sand before painting. It'll make the finish much nicer if the wood is smooth. From what I've read here you should be able to use any type of real life house paint but don't take my word on that. Someone else will be along soon with a better answer.
hi stephanie
before painting I usually try and sand everything to get a smooth surface, next depending on what you are painting I use a primer, let it dry, sand again and next apply a thin layer of the colour I want the door, windows etc etc etc to be. Let it dry and apply another thin coat untill you are happy with the texture and colour. I usually use acrylic paint that I thin with water.. Using multi-layers I think gives a more vivid result.
rgds
  • 3 weeks later...
I sand and fill any obvious problem areas with spackling compound and level it out and when it's dry I swand it again. I use flat white interior latex paint to prime with (I've also been known to prime with gesso, if it's plywood with chewy edges that refuse to sand nicely). I apply paint in light coats until I get the amount of coverage & color depth I want, letting the paint dry thoroughly between coats. I prefer to use satin or semi-gloss interior latex paint.
If I'm going to paper the walls I stop after priming and apply the paper to dry walls.
If I'm going to stain I sand, wipe off the dust and apply stiain with a soft rag in circular motions. When it's dry I go over it with a crumpled brown paper bag.
I don't usually seal anything.
