Turning a trinket box into a mini trunk
spottedcat83
Hi folks!
In my fear of building the actual dollhouse, I've been playing around with a bunch of smaller stuff (yeah, well, it's a bad pun, but what can I say? :) ) including a cheap little wooden trinket box, which I am attempting to turn into a Hogwarts trunk.
So I painted it black on the outside. Don't worry about the inside; I'm going to line it with some fabric, so it's okay. But the outside--I took some gold paint and put "brass" corners on it. The brass corners aren't perfect, and it's never going to be an exact trunk, because let's face it--it's a cheap wooden trinket box. But I'm trying for an approximation here, because I'm a beginner and not worrying too much about exactness at this point.
So.
Wow, that was a long explanation, wasn't it? :p
Does anybody have any suggestions that are fairly easy that might make it look more like a Hogwarts trunk? :flowers:
I'll put a sticker or two on it, so it'll look kinda Hogwarts-ish. I just can't figure out what to do to make it look like a trunk!
The leather shoelace idea is good--the only problem is that the shoelaces are so thick, they would have a 3-d effect that might confuse people. I wonder if there are any other leather, or leather-like, strap-like things I could use.
A picture... *sigh* I have a camera. I even found the cord. My problem is my stupid computer. It's old, and all the hookups are on the back. :p Kinda makes you wonder what computer makers were thinking about back then. I suppose they were thinking that we'd always want to just plug things in and that would be it.
No. What am I thinking? They were thinking that they'd invent new things, like USB drives, and they'd change the USB ports around, and all that... so we'd all have to buy NEW COMPUTERS! :flowers:
Mmm. I haven't done that yet!
But I will try to wrestle the computer around sometime soon and find the plug-in thingies for the camera.
Note my really technical terms... plug-in thingies... :)
You should be able to purchase a small piece of sewing leather at JoAnn's or a craft shop, or even cut a small strip from an old purse and use the soft leather instead of a shoelace. It would lie flatter. If it was from an old purse, it would even look aged.
Chris
Make sure it looks slightly dusty and old. You can add a bit of dust by using pastels shaved with a razor blade..then lightly spray your surface with a spray fixative so the dust doesn't get all smeary.
Seems like the whole of Harry's wizarding world was a trifle dusty, with everything looking slightly worn. But since that was before our modern megavaccuums, and dusters, it makes sense to me.
J
You might want to glue very thin leather or leather-look vinyl over the wooden exterior of your trunk. You can make wee "brass" fittings from foil painted brass color (Testor's makes a lovely breass paint that sticks to most everything) and straps from the same or a different color leather source. You'll want to line the interior with floral paper or fabric in a tiny design (Stained with old used teabags for that aged, splotchy effect). If you glue bits of toothpick to the sides of the interior and below the top a bit you can make a tray from cardboard or chipboard, covered to match, to go in the top.
