Margaret Posted June 27, 2009 Share Posted June 27, 2009 I was wondering if you can use peel and stick tiles for dollhouse flooring.Has anyone used this or can it be used? Quote Link to comment Share on other sites More sharing options...
parisbabe Posted June 27, 2009 Share Posted June 27, 2009 I have heard of peeps doing this but I cant see how it would work using it in just one room and not the other beside it since it would make it difference in the flow (level wise) between the adjacent room Quote Link to comment Share on other sites More sharing options...
justmesue Posted June 27, 2009 Share Posted June 27, 2009 Yes, I've used them! They work great! That's what's in my BH. They can be cut up into 1 inch squares and used as dollhouse scale tiles too. They wood pattern ones, look like real wood flooring. I'm always on the lookout for open boxes in hardware stores. Sometimes you can get acceptable patterns for pennies each, so the price is right too. Best of luck. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted June 27, 2009 Share Posted June 27, 2009 Absolutely the peel & stick tiles make terrific dh flooring. Tracy/ Minis on the Edge showed a floor using Rik Pierce's method of cutting grouting lines into the top layer of a tile to simulate stonework, and our own Greenleaf store sells tiles & floorboards ready-to-use, as I have in both the Magnolia and the Laurel I rehabbed: Quote Link to comment Share on other sites More sharing options...
More Minis Dollhouses Posted June 27, 2009 Share Posted June 27, 2009 I painstakingly cut real life size peel and stick vinyl tiles into small squares to do the floors of my very first dollhouse. I didnt have any experience in building back then. It works, but I wouldnt ever attempt to do it again. Quote Link to comment Share on other sites More sharing options...
debra Posted June 27, 2009 Share Posted June 27, 2009 OMG This is exactly what I am doing as we speak, no kidding, I am cutting up a RL foot square vinyl wood floor look tile into very thin strips to put on the floor of my rehab Beacon Hill, I cant beleive this, and yes it is working just fine, as the previous owner had stuck some kind of yukky felt onto the floor and I cant for the life of me get it off, so I am going straight over the top (Saving on bottles of valium and prozac here) I will put some pics in my gallery when I get a littel more done to it. Cheers Debra. Quote Link to comment Share on other sites More sharing options...
Steve_in_PA Posted June 27, 2009 Share Posted June 27, 2009 I have done the small 1" squares on several of my houses. I went to Lowe's & got regular floor tiles at less that $1 each & cut them down to 1" squares. In my album, under 'How I Did It' you can see one of the floors. I just clamped a metal ruler down on the tiles & used a utility knife to cut them. The floor must be free of dust to install them, so I use tack cloth to get the dirt off. Also, I make a template of the floor from newspaper first & lay the tiles on this. It is a lot easier to take the floor up if you ever want to change it. Steve in PA Quote Link to comment Share on other sites More sharing options...
Lisa_F Posted June 27, 2009 Share Posted June 27, 2009 The slate flooring in my front-opening montgomery is plain old peel & stick tiles cut into 1 inch squares. I stuck the tiles to template made of regular paper & then slid the whole thing into the house. I wanted the floors to be removable for wiring purposes. Quote Link to comment Share on other sites More sharing options...
macography Posted June 27, 2009 Share Posted June 27, 2009 Yes I have used it, except it was peel and stick vinyl flooring, just cut it and stuck it! Except you have to make shure you sand first, and sometimes put a primer on first, but don't glue it, it will ruin the bond. Quote Link to comment Share on other sites More sharing options...
Audra Posted July 3, 2009 Share Posted July 3, 2009 I used the tile in my sea side villa kitchen and painted the 'grout' lines in Quote Link to comment Share on other sites More sharing options...
Windsor Posted July 3, 2009 Share Posted July 3, 2009 I used the tile in my sea side villa kitchen and painted the 'grout' lines in That looks great! nice work :groucho: Quote Link to comment Share on other sites More sharing options...
ilovecats Posted July 5, 2009 Share Posted July 5, 2009 I love peel and stick tiles, i use them in every house. Quote Link to comment Share on other sites More sharing options...
Wolfie Posted July 5, 2009 Share Posted July 5, 2009 Love your Seaside kitchen floor. How did you get the grout lines painted so neat and straight and all?! You must have a very very steady hand! Beautiful floor! Quote Link to comment Share on other sites More sharing options...
Jo Med Posted July 5, 2009 Share Posted July 5, 2009 I've used them on my verandah and in my bathroom, the verandah ones are vinyl and the bathroom ones are a formica type material - vinyl is much easier to work with but the formica give a great finish, Jo Quote Link to comment Share on other sites More sharing options...
Gezgee Posted July 5, 2009 Share Posted July 5, 2009 I used peel and stick vinyl flooring. on my Newbery and i like how it looks Quote Link to comment Share on other sites More sharing options...
Deb Posted July 6, 2009 Share Posted July 6, 2009 I use the Greenleaf vinyl tiles and hardwood flooring and LOVE them! They're so easy to work with and I love the results. One tip that I can share to bring out the best in any peel and stick tile is to put a coat of poly gloss varnish over the top. Ooooooooooooh, the shine is soooooooooooooo pretty!! Deb Quote Link to comment Share on other sites More sharing options...
chellebelle Posted July 7, 2009 Share Posted July 7, 2009 Thanks for this topic! After reading all the posts,I thought I'd try it. We went to Lowe's, where I bought 2 different patterned peel and stick tiles for 88 cents each. I cut them into 1" squares and stuck them onto cardstock in a diamond pattern, and glued that to the floor. I'm putting them in the Rosedale that I'm rehabbing, that I'm going to offer to the neighbor who gave it to me. I scored them with a utility knife and snapped them apart, but it was tedious. I'm thinking that since I really like the look, I'd like to do more in other houses. So, I wonder if I got one of those old, heavy duty guillotine paper cutters I would have straighter cuts. Quote Link to comment Share on other sites More sharing options...
sparklepuppies Posted July 7, 2009 Share Posted July 7, 2009 Michelle, I have cut the tiles with my paper cutter, and it worked okay. It would probably work better with a newer sharper blade. Quote Link to comment Share on other sites More sharing options...
