janinelewis Posted November 20, 2008 Share Posted November 20, 2008 I am using the power strip to light a dollhouse. I am attaching the strip under the house. Some of my light's plugs are not long enough to reach the strip. How can I extend the wires if that's possible? Thanks! Quote Link to comment Share on other sites More sharing options...
judithfa Posted November 20, 2008 Share Posted November 20, 2008 I have increased the length of the wires on a number of lights. Buy some wire (HBS has it on a roll) online or at a dollhouse shop unless you have some on hand already. Remove the plug and attach the extra lenght to each of the wires by twisting the wires together tightly. Then wrap scotch or electrical tape over the join. Now attach the plug to the "new" end. I hope this makes sense Quote Link to comment Share on other sites More sharing options...
janinelewis Posted November 20, 2008 Author Share Posted November 20, 2008 Thank you so much Judith! I kinda thought that's the way it was done but wasn't quite sure. Quote Link to comment Share on other sites More sharing options...
KathieB Posted November 20, 2008 Share Posted November 20, 2008 Electrical tape is a better insulator than transparent tape. You wouldn't want a mini electrical fire to happen! You can also get shrink tubes at HBS & Cir-kit Concepts to use instead of tape. Slip one over one wire, twist the joined pieces, slide the tube over the bare wire, then shrink with a hair dryer. You can also get wire at Radio Shack or similar shops. Take the light with you, so they'll know what wire you need. Quote Link to comment Share on other sites More sharing options...
Starfire Posted November 20, 2008 Share Posted November 20, 2008 I have had to lengthen or shorten lighting wire a number of times. I usually save the excess wiring left over, providing it is enough to save (lol) and use that for extending the needed wiring for a light. Quote Link to comment Share on other sites More sharing options...
Corwin Posted November 20, 2008 Share Posted November 20, 2008 Uhg i am working on the Garfield, i have 3 runs going to 3 different transformers, my advice label them if you can any way, can you use those mini extension cords? Quote Link to comment Share on other sites More sharing options...
justmesue Posted November 21, 2008 Share Posted November 21, 2008 I do not try to lenghten my wires. I use single receptacle extension cords, and just plug the lights in and have an extra 6 feet, to get the power where it's going. You can also buy triple extension if you have more than 1 light in a room that won't reach. I feel safer doing this. Quote Link to comment Share on other sites More sharing options...
