Minis On The Edge Posted December 11, 2007 Share Posted December 11, 2007 Kelly, I added the links to this pinned section so we will be able to find them later on Quote Link to comment Share on other sites More sharing options...
Josje Posted December 11, 2007 Share Posted December 11, 2007 (edited) Can someone please translate this for me.. I am wanting to try and make one and don't quit understand.. http://www.poppenhuisdroom.nl/homepage/sho...paginaid=223516 You want to make the harmonica? I'll translate it for you, I'l just need a little time! PS: Are you OK with metric? Edited December 11, 2007 by Josje Quote Link to comment Share on other sites More sharing options...
jeninky Posted December 15, 2007 Share Posted December 15, 2007 Thank you for the translation!!! Quote Link to comment Share on other sites More sharing options...
jeninky Posted December 18, 2007 Share Posted December 18, 2007 For those of you who knit here is a link for 12 free patterns for tiny sweater ornaments... http://www.berroco.com/exclusives/minutia/minutia.html Quote Link to comment Share on other sites More sharing options...
jeninky Posted December 18, 2007 Share Posted December 18, 2007 Hope that you enjoy! Mini hugs Jennifer Quote Link to comment Share on other sites More sharing options...
snarkalicious Posted December 24, 2007 Share Posted December 24, 2007 I ran across this today while trying to find a tute on making my own wallpaper. http://www.geocities.com/justauntb/index.html It's for Paint (which I don't use) but is easily translated into Photoshop (which I use obsessively). Quote Link to comment Share on other sites More sharing options...
grynche Posted January 22, 2008 Share Posted January 22, 2008 I was looking for a way to make mini-paint tubes for an artist's box, and ended up finding out how to make metal dog bowls. Go figure. http://www.dukkehussiden.dk/dukkehus_tallerkner.htm I haven't translated this, but the pictures are mostly self-explanatory. 'cept I can't figure out what the hacksaw is for. I'm a bit fuzzy on the transition from aluminum roasting pan bottom to the embossed finished product, but I'm working on it. Quote Link to comment Share on other sites More sharing options...
Corwin Posted January 22, 2008 Share Posted January 22, 2008 :lol: some one may have posted this, ah well http://68.38.137.242:8090/dh/DIYProjects.htm Quote Link to comment Share on other sites More sharing options...
Anna Posted January 22, 2008 Share Posted January 22, 2008 I was looking for a way to make mini-paint tubes for an artist's box, and ended up finding out how to make metal dog bowls. Go figure. http://www.dukkehussiden.dk/dukkehus_tallerkner.htm I haven't translated this, but the pictures are mostly self-explanatory. 'cept I can't figure out what the hacksaw is for. I'm a bit fuzzy on the transition from aluminum roasting pan bottom to the embossed finished product, but I'm working on it. Hmm, now I can translate that for you as it is in Danish and that is very close to Swedish :lol: Will look into it when I get home this afternoon Hugs Quote Link to comment Share on other sites More sharing options...
grynche Posted January 22, 2008 Share Posted January 22, 2008 Hmm, now I can translate that for you as it is in Danish and that is very close to Swedish Will look into it when I get home this afternoon Hugs Oh, that would be lovely. I tried Babel Fish but there was no listing for Danish to English. The only part I'm really confoozled about is the foil that's used. That and the hacksaw. :lol: Quote Link to comment Share on other sites More sharing options...
Anna Posted January 22, 2008 Share Posted January 22, 2008 Well here goes a veeeery rough/QD translation: Can be painted , the decor are "stickers". Use aluminum pans, plates and the likes. THey recommend you ask your local sandwich shop for their "extras". These pans's foil is pliable enough to be worked on with wooden dowel and things like that.' Use plates and things you have around like bolts and wing nuts (?) etc for the shapes you want to create, buttons or other stencils might work as well. The making is simple enough, put your "shaper" on an appropriate surface, put the foil on top use your dowel to push it all the way out to the edges with it. Be sure to carefully press the edges over and down the outside as well showing the bolt. THe foil is then turned and re-shaped releasing the shaper object. Cut away the superfluous material, gently sand the edges smooth. For making bowls, use marbles to press down with giving it the rounded shape. The hacksaw is to make your own sized holes, ie if you have a piece of scrapwood you want to use you can cut away the hole and then shape the side and have your own mold to work with. THe embossed f oil seems to be a lucky find really, perhaps from a shop or something??? But I do know that one can emboss the aluminum pan with a sharp tool as well, perhaps that would be worth a try? Hope it helps to "decomfoozle" a little. Hugs Quote Link to comment Share on other sites More sharing options...
Corwin Posted January 22, 2008 Share Posted January 22, 2008 me too. What IS that hack saw used for???? EDIT: Big boo boo i didn't see, Anna's post....Never mind.. Quote Link to comment Share on other sites More sharing options...
Anna Posted January 22, 2008 Share Posted January 22, 2008 Just in case you don't have nuts and or bolts to use as frames LOL, you can make your own sized frames, make a starter hole and then saw away the inner portion where your plate will dip so to speak, shape the outer rim and you have a perfect mold for your work! Hugs Quote Link to comment Share on other sites More sharing options...
grynche Posted January 23, 2008 Share Posted January 23, 2008 "decomfoozle" ................... I love it! Thanks so much for explaining the process more better for me. Especially the hack saw. I stopped at the Dollar Store after work for some foil pans. Play time. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 23, 2008 Share Posted January 23, 2008 You can shape paper plates with a dowel and use a mouse pad to press into, I wonder if the foil would be too heavy to work for that. I thought it was a terribly clever idea. BTW, did you ever make your paint tubes? Quote Link to comment Share on other sites More sharing options...
Corwin Posted January 23, 2008 Share Posted January 23, 2008 Just an idea one of my sisters had those embossed trays at her wedding, so check the bridal shops. Quote Link to comment Share on other sites More sharing options...
grynche Posted January 23, 2008 Share Posted January 23, 2008 You can shape paper plates with a dowel and use a mouse pad to press into, I sonder if the poile would be too heavy to work for that. I thought it was a terribly clever idea. BTW, did you ever make your paint tubes? Not yet. I eventually found one small pic and two lines of directions. Fold foil over a bit of toothpick, crimp the end and add a blob of clay for the cap. It's a start. Quote Link to comment Share on other sites More sharing options...
Anna Posted January 23, 2008 Share Posted January 23, 2008 Not yet. I eventually found one small pic and two lines of directions. Fold foil over a bit of toothpick, crimp the end and add a blob of clay for the cap. It's a start. What about using white seed beads for caps and add a touch of paint to cover the "hole" and use as colour indicator. And glad that it might help with the plates! Hugs Quote Link to comment Share on other sites More sharing options...
Shelly N Posted January 23, 2008 Share Posted January 23, 2008 If you have old mini mags you can find articles on these ....I searched the project database on the name site and found that Dollhouse miniatures Issue 4/02 Nutshell News Issue 6/89 and Miniature Collector Issue 7/01 has paint tube projects. Quote Link to comment Share on other sites More sharing options...
grynche Posted January 23, 2008 Share Posted January 23, 2008 Don't have any magazines, but thanks. I think I've got a pretty good idea on the paint tubes, and I've some printies, too. I'll take some measurements this weekend at Michael's, and come home and play. Quote Link to comment Share on other sites More sharing options...
Rhonda Posted January 29, 2008 Share Posted January 29, 2008 (edited) From the book Dolls' house details by Kath Dalmeny: Paints: model tiny paint tubes from polymer clay about 5/8" long. Once hardened paint them silver. Cut strips of paper for labels. Draw colored lines on the tops and bottoms, and add tiny black lines for text. glue the labels around the paint tubes. here is a picture sorry about the quality but I scanned it from the book and it lost some clarity in the cropping and resizing http://www.greenleafdollhouses.com/forum/uploads/gallery_2577_1630_7092.jpg Edited January 29, 2008 by Rhonda Quote Link to comment Share on other sites More sharing options...
grynche Posted January 29, 2008 Share Posted January 29, 2008 Ooooohhhhhhh, they're wonderful. Thanks, everybody. I even bought some silvery clay at Michael's sale this past weekend. Quote Link to comment Share on other sites More sharing options...
Shy Spirit Posted January 29, 2008 Share Posted January 29, 2008 From the book Dolls' house details by Kath Dalmeny .... That is an excellent book. I have it, and it's full of great projects! Quote Link to comment Share on other sites More sharing options...
grynche Posted February 14, 2008 Share Posted February 14, 2008 Making stairs, various sizes and styles, paperclay and cardboard.....the ones in the tutorial are curved. The tutorial is involved but well done. I have an idea for a project with a circular staircase but balked at the price of ready-made ones. This might work. http://www.minimotion.com/HOWTO/Stairs/stairway%20howto.html Not that I was looking for staircases when I found it. Quote Link to comment Share on other sites More sharing options...
grynche Posted February 14, 2008 Share Posted February 14, 2008 Tutorials and printies on: quarter scale bookcase and books; multi-scale toilet paper; spiral bound notebooks (not sure of the scale.....they're about 1/2" x 1/2" ); a suitcase. [while the boss is away, I does play :wub: ] Quote Link to comment Share on other sites More sharing options...
