robedsaul Posted December 29, 2005 Share Posted December 29, 2005 I've begun my first dollhouse ever, the Arthur, which I receive as a Christmas present, so I'm sure this will be the first of many questions! I didn't receive siding for the house, but it does say in the directions that siding can be put on it. So I purchased 3/4" wood veneer in a roll at the hardware store for this purpose. This siding is made so that it could be ironed on flat. I know I don't need to apply it like that -- wood glue, right? Now...do I put it on first, then the window and door trim, or vice-versa? Do I paint it first and then put it on, or vice-versa? I'm clueless, and want to do it the best way to save myself aggrevation later. I've looked over the directions and they don't seem to provide any guidance in this area, I guess because the siding material wasn't included in the first place. Thanks so much for any help you can give me! Heather Quote Link to comment Share on other sites More sharing options...
havanaholly Posted December 29, 2005 Share Posted December 29, 2005 I used shingles on the Arthur's second floor, my first foray into siding was the Westville. I put on the siding, then I painted it, then I applied the trim. Apparently the kit is made to put the trim on first and then butt the siding up to it, but I'm not that tidy ; I had to trim some of the trim to compensate for the bulk where my measurements failed. You may have better luck painting your veneer first, but the siding strips I used on the Westville were cut from the same very thin (balsa?) as the shingles and curled like gangbusters until dry, I used over half a roll of masking tape trying to control the curl from the wood glue, and then go back & do it again from the paint. There are faster setting glues that people use; I use what I've got. Quote Link to comment Share on other sites More sharing options...
