luvmypoodle Posted May 28, 2005 Share Posted May 28, 2005 How do we get other avatars, is there a site, is it free? Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted May 28, 2005 Share Posted May 28, 2005 You can add your avatar by checking out the same link under "My Controls". Yes it is Free!! :lol: Quote Link to comment Share on other sites More sharing options...
havanaholly Posted May 28, 2005 Share Posted May 28, 2005 JJ, I think you can import a picture from your Webshots to use for an avatar, check under the avatar setting on "my controls". Quote Link to comment Share on other sites More sharing options...
Mini Man Posted May 28, 2005 Share Posted May 28, 2005 How do we get other avatars, is there a site, is it free? If you go to My Controls\ Edit Avatar Settings you will see that there are four galleries you can browse for Avatars. I have a bunch more to upload so check back later in the weekend for a wider varity. You can also upload your own pictures. The forum will automatically resize it to 100 x 100 pixels and will convert it to a JPEG. If your picture isn’t square, it will work with the longest side and reduce it down until that side is 100 pixels. So in a nut shell, it doesn’t change the aspect ratio to make it look like a mirror in the fun house. If you are working with a picture that has a transparent background, the forum will convert the transparent area to black which might not look to good. It you be wise to replace it before you upload the image. The Forum background color is #ECEDED, so if you change the transparency to match, it will still appear to be transparent after the upload. I hope this helped! Dean Quote Link to comment Share on other sites More sharing options...
