Primerose Cottage
I wanted do something different to the Primerose Cottage again so I wanted to add more light to the upstairs so I added a dormer window. I also wanted to add more hight to the ceilig so I took some foam core and added 3 inches right where the slots to the floor begins. After thinking on this, I decided to use Gatorboard because I was worried that the clay would warp the foam core:
I also wanted to add a fireplace on the inside and I wanted a chimney so I used the foam core and cut it to look like a chimney on the outside:
I then added Wood Beams because I plan on making this a tudor styled cottage:
