Almost there
Well as I said in my last entry the interior is almost there. A couple more things and it's done - it's the exterior that's been perplexing me now, but it too - finally- is almost there. I've gone over some of the paint to try to even it out - it's still too dark but I'm afraid that's just how it will have to be. I've found I an lighten it but it lightens very unevenly so I'm going to let it be dark. I've also spent a bit of time filling cracks, filling window gaps and in general just trying to smooth out the over all look of it and make sure there aren't any glaring "oops"es showing.. and there still may be a few I haven't spotted. I painted the under side of the eves - something I'm now wishing I'd done before assembly :angry: And I've been working a few details that I hope will add just a few nice touches to the place.
I used the wooden door frame that came with the kit on the inside and planned to do the same with the exterior of the front door but apparently I misplaced it.. which is probably not such a bad thing because it forced me to do some block work there which I think will make it look more finished in the long run. Here's my block work around the front door exterior and a block step which is paperclay over the hard styrofoam. As you can see I still have some painting touch ups to do.
Once this is completely dry and I'm satisfied that all gaps there have been filled it will finally be time to add on the entry way permanantly but I've been working on a shield for the interior. I found an image of a shield I liked (from one of the small ones I had on the interior back wall) and I sculpted it in polymer clay the size I want it - then baked the shield. Once it was baked I made a press moldl also in polymer clay from it and baked the mould. The next step was to make a mould out of paperclay which will keep the weight down. Below is the mould and the paperclay sheild that came out of it - the last step will be to paint it then put it on the wall.
As you can see in the above picture there is also a smaller mould there made directly off one of the tiny shields I had up - In this case I just used the original to make the mould from in order to do this:
Unfortunately right now the small paperclay shield, unpainted looks like a nose beneath two hollow eyes but once it's attached and painted it should be a great detail to add to the entryway above the arch - at least that's my hope :lol:
6 Comments
