Flower Border Class Steps 5 - 8
Press the sheet Moss on the glue be careful because it may be hot. If you are using a bird bath or something, Now is the time to add it in the center. Try to have it the same amount of space in the front and back.
Now add a bit of glue in the corner like this
Add glue right below that spot like this. Then add sheet moss to it the same way you did the other part.
