    302
    199
    249,343
Window-works.
rbytsdy
Got my papers glued on:
large.IMG_4100.jpg.54d43714d3331229ded4a
As per usual, spending extra time on the windows. Decided to go with modification of Kris' matboard windows-- I'll leave out the sashes because they add weakness to the window structures (but mostly because they are difficult enough for me to get straight, speaking from experience, let alone those evil curves :p). Fit each casing to each window opening, using Kris' scored matboard trick to do the curves:
large.IMG_4101.jpg.9981a6af44d1db11146b2
A lot of gessoed and framed casings: And installed:
large.IMG_4102.jpg.c3f40998337d7a66f8f5elarge.IMG_4104.jpg.d196d236d32d4c4abd624
I'll glue the transparencies to the other side, and add some mullions here and there. Can't add the outer frames until the siding is done, though. Used Kris' door tutorial for the front door-- love how clean and crisp the lines are-- so much better than those die-cut doors turn out.
large.IMG_4103.jpg.de7063dda7a81ed652ec2large.IMG_4105.jpg.5c9d4d66c849c0130f96d
1 Comment
