Even more color for the San Fran.
I went ahead and installed the 3rd floor partition and the little attic floor; I didn't want that long narrow space at the very top, but I didn't want to close it off entirely, so I made a little triangular wall out of foamboard, cut a hole in it, mounted one of the lights behind it, and framed it with a jewelry finding (with a bit of "glazed" translucent scrapbook paper that lets the light out but prevents seeing the nuts and bolts behind it). I also installed the two remaining lights beneath the attic ceiling.
The decorative posts (that hide the vertical partition wall edges) aren't glued in it, just dry-fit until I get all the flooring in.
Figured it was time to get on to the flooring, so I tried something different (I think I saw it on miniature madness blog)-- wood veneer cardstock, that I got from Amazon. I cut it (exacto) into strips, then glued them onto a cardstock template.
It is pretty good-- have to be careful with it because it is a very thin wood layer over card, but it isn't too fragile. I haven't tried sanding it yet-- will have to proceed with that carefully.
After installing the flooring (upholstery "carpet" in the 2nd floor bedroom), installed the staircases; had to get creative with bracing the partition wall from the other side so as to get a good bond on the staircase side:
Oh-- finally finished shingling the front gable! All those pastel-colored shingles remind me of those round tart candies. Glued on the decorative edge trim.
Now, about those corbels that you can see on Robin Carey's San Fran at the tops of the window trim sides, that are painted yellow and purple-- I didn't know where to begin looking for them, so I decided to make my own out of matboard and foamboard. I used my dremel to round off the edges of the matboard, and my exacto to bevel the sides of the little foamboard squares.
I'm pretty pleased with how they turned out--
Now I'm working on the front railing. If one looks carefully at Robin's house, one can see that the 2nd floor spindles have a slightly different color pattern than the ground floor spindles.
I also put the large trim pieces on the tower; I am planning to make the tower roof removable so it won't be so unwieldy to ship.
Need to start thinking about the roof shingles.
3 Comments
