4.) Section N. Roof and Trim
Section N. Roof and Trim1 I will not add the trim in this step. All I want to accomplish here is a sturdy, squared house.2. There were no big problems here. I had to pull at the Center Wall at the attic to straighten the wall, but other than that, everything fit where and how it should: a perfect roof. I am using lots of masking tape to hold the roof together until the glue dries. I used a “set square” to make sure walls were vertical as I put the attic floor and the roof in place. 3. Now that the house is square and vertical, I will go back to some of the previous instructionsSection - Stair AssemblyI did a test fit, and then removed the assembly. This makes it possible to paint or paper the wall. Then I will put the stirs in permanently.http://www.greenleafdollhouses.com/forum/\html\style_emoticons\/tongue.png' alt=':p'> Complements of judithfa
1 Comment
