My Name Is Linda & I Am Addicted To Making BRICKS
Hello! My name is Linda, and I am addicted to making bricks out of paperclay. Don't believe me? Just check it out then.
First, I need to brick the inside of my fireplace chimney, right in here, so I need to roll out some paperclay. Then once I get the paperclay in that area (and I had to first put the chimney onto the house and insert the wooden floor thingy and draw me a line so I wouldn't paperclay over that portion), then I have to "stipple" it, which is just taking a small (1 inch maybe) paint brush which has had the ends cut to "blunt" it up and tapping that on the paperclay. Gives it a very nice texture. Then I begin cutting in my bricks.
Then I start on the outside of the chimney, putting my paperclay on. I cut a half inch strip of paperclay and wrapped it over the paperclay on the top to make a "cap".
Somehow on this side, I must have cut the clay too short when I was going around that edge and I've got a little gap there. So, I take a bit of paperclay and roll it, making sort of a string, and then I lay it on there and use that little purple tool to smooth it down into my crack. Crack is all filled up now.
Now, this is probably one of the ONLY times that I actually go by and actually make a measurement! I'm creating a design on the lower chimney, and to do that I'm using my ruler (this one is metal with a cork back--I like it better than wooden ones), my little gray tool, and my little white tool.
I'm coming roughly 3/4 inch off each side of the chimney, and I'm beginning a design. I make "cuts" in the clay certain stages up so that I will know where I need to be when cutting in the design. Then I'm going to go about 1/4 inch on the inside of what I have cut and do that again.
At the top, I want a -- I can't remember the name of it -- but I'm putting in another design. I lay my gray tool on it and begin cutting around the gray tool. I have lines in the center of that once I am done, so I just use the end of my purple tool and smooth that back out.
And now, what I REALLY use that ruler for--TO CUT BRICKS, LOL!
My clay was starting to dry on me, so I had to cut fast. Here's the first step of the brick design.
Now, on the inner part of the design that I made on the lower chimney, I'm going to create a new brick design. I start with two cuts--yes, using a ruler--and then I use that to complete my design on the bricks here.
TA DA!!! I have finished cutting all my bricks and have cleaned all my mortar lines.
Now, on to PAINTING BRICKS!!!!
Compliments of LPCullen
- 2
3 Comments
