more photos
I'm including some photos from this week. I still need to finish siding the tower and the little hard area by the roof, then the siding will be completed! I got impatient to see how it would look so i applied one coat of paint to the front of the house. i think it will need another 3 coats before i get the look i want (i applied 3 coats to the area under the porch and it still could use one more). I still need to finish the porch, sand the porch roof/balcony as the joints are uneven, apply a coat of spackle to level these areas out. After that is sanded, i'll probably go with the light colored tiles that Greenleaf sells for the porch/balcony roof. I'm going to have wire wicker furniture here and a few potted shrubs and some potted flowers.
After i completely finish painting the siding, i'll apply the corner trim pieces. I want a nice clean look. The house is getting closer to completion but it still needs alot of work. I'm very happy with the look of the siding. I used Quick Grap glue and it held the siding down pretty well with no warping. There were a couple of pieces that didn't stick down well, i'm sure because i was in a hurry and didn't make sure they were glued well. I put a little quick grab on a scrap piece of siding and slid the scrap siding under the non glued siding on the house. it worked well to fix the problem.
For the lower portion of the bay windows i'm pretty sure that i will use shingles to add a different look. i'm not sure if i will use the burgundy paint or the cream on those shingles. We'll see, i may have to experiment.
3 Comments
